03-27-2013, 07:40 AM | #1 |
Newbie Join Date: Mar 2013 Location: alyangula
| Problems!
hi, i have 2 lipo batteries. charger says they are full, plug them into the car and they don't work, i got a new battery which works fine but when ever i charge the old ones it says Low Voltage.. :/ any ideas on what could be wrong, and while i'm here what electronics is recommended to replace/change on the SCX10 trail honcho? cheers |
03-27-2013, 07:54 AM | #2 |
| Re: Problems!
You ran it down too far. If it says low voltage, it's garbage. Do not keep charging it, it could start a fire... happened to me. |
03-27-2013, 07:59 AM | #3 |
| Re: Problems!
Ok cheers for that. so there ****ed :/ damm more money for more batteries :(
03-27-2013, 08:19 AM | #4 |
| Re: Problems!
Yeah, I got tired of trowing away expensive lipo's... I get them here now: Value Hobby R/C Hobby Store (Bensenville, Illinois): Batteries - Power |
03-27-2013, 08:57 AM | #5 |
| Re: Problems!
Can you link me to a Suitable Battery for my scx10?
03-27-2013, 09:04 AM | #6 |
| Re: Problems!
Are you currently running 2s? I own 4 trucks with Axial axles but have never owned a Honcho... or stock electronics so don't know much about them. I think this will fit but you should measure first: Value Hobby R/C Hobby Store (Bensenville, Illinois): GForce 60C 5900mAh 2S 7.4V LiPO if not, this will: Value Hobby R/C Hobby Store (Bensenville, Illinois): GForce 30C 2200mAh 2S 7.4V LiPO do you have the money to upgrade electronics? If so, and you want to stay brushed: Holmes Hobbies BR-XL and a HH motor will be a great upgrade. If brushless, Tekin Pr04 3300 or lower (the ROC motors) |
03-27-2013, 09:16 AM | #7 |
| Re: Problems!
Yer i run 2SC 4200mAh Lipo, Another over 5000mAh will turn my charger into a fireball :/
03-27-2013, 09:26 AM | #8 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| Re: Problems!
had a guy I work with claim that too recover over discharged Lipos he can use the NiCd setting and charges at a low rate till cut off voltage is reached and then charges them on up with the right settings. that being said, I would never attempt it.
03-27-2013, 09:46 AM | #9 |
| Re: Problems!
I've tried it on the NiCd at 0.1A and still nothing :/
03-27-2013, 09:50 AM | #10 |
| Re: Problems! |
Problems! - Similar Threads | ||||
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
ax-2 problems | nhtoyotawheeler | Electronics | 6 | 03-17-2011 08:17 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
Problems | bikemikeb | Electronics | 5 | 06-16-2008 08:10 AM |
Having problems | derwood21 | Electronics | 6 | 03-31-2008 01:55 PM |
