03-27-2013, 07:16 PM | #1 |
Rock Crawler Join Date: May 2011 Location: at your moms
| hh brxl issues
i have a brxl that ive been running, i ran it last night and today without issues, i changed batteries and it will beep 3 times and i apply throttle and the red light will come on like its trying to apply power to motor and notta, steering works fine, unplugged it 10ish times and it finally synced up correct, unpluged it and same thing wont send power to motor, tried several batts to make sure its not hitting lvc and tried another motor wth no luck Ron running it on 3s 25c batts
03-27-2013, 07:33 PM | #2 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
Sounds like it could be battery/esc connection problem. What plugs you have on you battery/esc?
03-27-2013, 07:48 PM | #3 |
| Re: hh brxl issues
i run deans on everything
03-27-2013, 08:21 PM | #4 |
Maybe a bad solder job on one of the solder points or the solder is falling apart from being old? Perhaps the one of the deans had melted a bit while soldering thus causing the either contact strips to move preventing a good contact. I've the last happened to me and haven't fixed it yet, so now I just leave the dean separated just a hair so my rig works. I'm running a brxl as well:thumbup:
03-27-2013, 08:34 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: hh brxl issues
I would double check that battery! Sounds like a low battery or one with a low c rating! |
03-27-2013, 10:21 PM | #6 |
| Re: hh brxl issues i tried several different batts thinking the same thing as you, i found out what it was, it was a crappy solder job on the deans on the motor, resolderd and away i go thanks guys Ron
03-27-2013, 11:04 PM | #7 |
| Very welcome. Glad you got it taken care of...we don't like it when someone can't trail due to technicallities:thumbup:
hh brxl issues - Similar Threads | ||||
BRXL Giveaway & The Next Team Driver Contest - 1 RCC User will win a BRXL this week!! | Locked Up | General Crawlers | 205 | 10-22-2012 10:49 AM |
brxl and 10 turn puller issues | bikerpyro | Electronics | 5 | 09-17-2012 05:49 AM |
Brxl issues. | Roman5150 | Electronics | 21 | 01-11-2012 07:16 PM |
