04-01-2013, 02:21 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Need esc help
So Ill get right to the point. I have a hh Brxl and I have deans plugs on both the motor leads and the battery side of the Brxl. I accidentally plugged my battery into the wrong side of the Brxl. I instantly saw some smoke and unplugged it right away. Now when I plug it in my bec just blinks and makes a ticking noise and nothing else works. So I'm assuming I burned up the Brxl? Can it be fixed? |
04-01-2013, 02:38 PM | #2 |
| Re: Need esc help
Can it be fixed? Yes. Is it cheap? Nope...."user error" Maybe John will be nice, but you did the error (now on the Internet) and we shall see what Holmes Hobbies decides. Most vendors here are reasonable, but they have to make a living as well. |
04-01-2013, 03:15 PM | #3 |
| Re: Need esc help Ok I'll send him a pm.
04-01-2013, 03:24 PM | #4 |
| Re: Need esc help
Fried it and most likely the CC BEC. Aaaaand now you know to use opposite Deans plugs on your ESC motor side.
04-01-2013, 03:30 PM | #5 |
| Re: Need esc help
Is there a Way to test my bec?
04-01-2013, 03:32 PM | #6 |
| Re: Need esc help
Plug it into a battery and take a voltage reading on the other side with a multimeter, or hook it up to something that needs power, like a servo.
04-01-2013, 03:35 PM | #7 |
Newbie Join Date: Mar 2013 Location: Fremont
| Re: Need esc help
Could just remove the bec if that is a option.
04-01-2013, 04:31 PM | #8 |
| Re: Need esc help
I sent him a email so ill wait and see what he says. I know it's my own dumbass fault and didn't want to lie about it. Thanks guys
Need esc help - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
