04-01-2013, 05:27 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| ESC Help!!!
Ok the led on my AE-2 is blinking red and green. dont know what it means googled and searched here and didnt find an answer. so can someone please help me? Thanks in advance, Kenneth |
04-01-2013, 05:30 PM | #2 |
Newbie Join Date: Feb 2013 Location: Canada
When I got mine it did the same thing. I just set the trims all to zero and restarted it.
04-01-2013, 05:34 PM | #3 |
| Re: ESC Help!!!
it happens when i plug in the battery (i removed the switch)
04-01-2013, 05:38 PM | #4 |
| Re: ESC Help!!!
ok it no longer is blinkng but it odes blink like it should when throttle and reverse are held but the truck doesnt move
04-01-2013, 05:48 PM | #5 |
| Re: ESC Help!!!
found problem loose motor wire but esc doesnt make any beeps
04-01-2013, 07:16 PM | #6 |
| Re: ESC Help!!! The ESC does not "beep" or "chime", the motor does that. A loose wire, bad brushes, etc. can prevent hearing the "chime" when the ESC boots up. Did you calibrate the ESC to the RX? Castle Creations | FAQ: 1/10th Scale Products Last edited by Charlie-III; 04-01-2013 at 07:18 PM. |
ESC Help!!! - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
is the traxxas xl-5 esc a good starter esc for axial kit | Misfit7734 | Electronics | 5 | 04-21-2009 03:59 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
