04-06-2013, 05:45 PM | #1 |
Newbie Join Date: Jan 2013 Location: Home
| motor smoking, help please
I have been running my ax10 xc1 for quite a while now on a 35t motor, and it's been doing pretty good, but today when I ran it through a puddle and tried to go up a hill the motor started smoking, so I let it sit for a while and then it ran fine until I did it again. (Note: I have water proofed it.) I have a few ideas on what's happening: 1: There's something in the motor and I just need to clean it. or 2: The truck is too heavy and I burnt up the motor, (the truck does weigh ten pounds). I would not want to tear apart the motor and clean it and everything and then find out the motor is broken, so any info would be helpful, thanks. |
04-06-2013, 06:08 PM | #2 |
Rock Stacker Join Date: Nov 2011 Location: Lehighton, PA
| Re: motor smoking, help please
is it actual smoke? or steam? maybe the water trapped in there burning off? does it smell burnt?
04-06-2013, 06:46 PM | #3 |
Yeah, I think it was smoke, it did smell burnt, and it did not want to move. Oh yeah, I just found out that the motor can't come apart.
04-15-2013, 03:16 AM | #4 |
Newbie Join Date: Mar 2013 Location: Central city
Well if you've smoked the motor twice now it won't be long before its done for good at the least you've weaked the motor and it won't have the same power it did originally brushed motors are cheap I would just purchase a new one
04-15-2013, 06:00 AM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
With motor having been hot and running it through the cold water has probably shocked or cracked something in the motor. Pull the motor and check to see if everything looks Ok . Then check the brushes and make sure they don't need replacing. The armature may need turning too. Since you have been running the motor for a while it may just need a complete rebuild.
04-15-2013, 08:45 AM | #6 |
how did you waterproof the motor? if you sealed it up no wonder it fried.
04-15-2013, 08:49 AM | #7 |
Pebble Pounder Join Date: Jul 2007 Location: Oveido, Florida
Im gonna go with its broken
motor smoking, help please - Similar Threads | ||||
Smoking Motor | evolution21 | Axial Wraith | 1 | 01-30-2013 01:07 PM |
Smoking motor | Zuest | Newbie General | 2 | 12-22-2012 07:23 PM |
smoking motor | codydray | Electronics | 11 | 05-16-2010 01:24 AM |
Smoking Motor | Alpha Male | Losi Micro-Rock Crawler | 15 | 12-15-2009 01:08 PM |
motor is smoking | bigdog5332 | Electronics | 10 | 03-22-2008 12:09 AM |
