04-11-2013, 01:43 PM | #1 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Fxr & 35t tekin bec question
I know this is a noob question but I'm thinking about getting this set up and I've heard talk about if running 3s you need a external bec, but I'll only be running 2s do I still need a bec? I'm running brushless in my other rigs and I don't run a bec so I'm still new to the thought of a bec
04-11-2013, 02:41 PM | #2 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
My wife's scaler has had an fxr in it for about a year now woth no bec..it's only run on 2s and only has a hitec 5645 servo in it..hasn't given me any problem at all.. -sent from my smarter than me phone |
04-11-2013, 02:42 PM | #3 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
BECs are always a good idea in an off road rig, especially brushed ones where motor efficiency is much lower than brushless. Any decent BEC will do: Castle, Novak, etc will all do the trick. Short of a BEC, a glitch buster cap plugged into the receiver will work for lighter duty, like trail use. |
04-11-2013, 03:00 PM | #4 |
| Re: FXR & 35T Tekin BEC question
A lot depends on the servo, if under ~200inoz you should be OK with no external BEC. If over ~200inoz, you should look at an external BEC. Most other wheeled rigs use lower torque output servos, thus no issues. If you need an external BEC, I suggest the 10A Castle Creations BEC. If your servo can handle it, you can run power wires direct from the pack to the servo (assuming 2S LiPO). |
04-11-2013, 04:42 PM | #5 |
| Re: Fxr & 35t tekin bec question
Thanks for the info, just order up the fxr & 35t and a cc bec 10a, my servo is a savox 166oz of tourqe, I'll be running only 2s
Fxr & 35t tekin bec question - Similar Threads | ||||
Tekin FXR/35T combo question | Planespotter | Electronics | 9 | 08-22-2010 09:10 AM |
