04-14-2013, 11:26 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| looking for longer run time...
I was out on the trails yesterday and was running my 3s 2200 lipo. Not sure on exact runtime as i dont keep track of time while im having fun. So to my question.. what is the best way or tricks to get crazy long run times? I really didnt like carring my rig back down the trail for a mile..lol some of the specs on my rig, wrekluse chassis, ar60 axles, 2.2 roklox, ax trans with vp dig, fxr esc, hh 35t puller, 2 savox 1283 servo's for 4ws, cc bec, servo winch. Just looking for ideas. Im not looking to take things off the rig to cut weight. Thanks |
04-14-2013, 11:35 AM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: looking for longer run time...
Try a higher mah lipo, or buy extra lipos and carry them with you
04-14-2013, 11:38 AM | #3 |
I run a 5300 mah 2s speedpack in my Scx weighs about 8lbs running a fuze 17.5 brushless and I can get about 5 hours or longer depending on how I drive
04-14-2013, 11:39 AM | #4 |
What is the best hi mah battery for the. Im still learning the whole lipo thing..lol
04-14-2013, 11:43 AM | #5 |
| Re: looking for longer run time... |
04-14-2013, 11:43 AM | #6 |
I'm still new to lipo my self but I have one speed pack 5300, and two 5000mah turnigy and two 4000mah turnigy and I get good run times with all of them, and turnigy lipos are pretty cheap, I got the two 5000mah 2s for 50$ shipped
04-14-2013, 11:44 AM | #7 |
Sometimes ya gotta crawl up a spot and sometimes it's full throttle for a steep hill climb just depends on the terrain
04-14-2013, 11:53 AM | #8 |
So i was thinking about going from 3s to 2s and changing out the motor to like 20t or something like that. Do you think a change like this would help run time?
04-14-2013, 11:58 AM | #9 |
Easiest way would just go higher mah lol you run a 2200 go up to a 5000
04-14-2013, 12:47 PM | #10 |
Rock Crawler Join Date: Oct 2012 Location: Casper
I run a 5000mah 3s 20c (I think, it's been plastidipped so kinda hard to read, now. LOL) and I've never been able to run it to the cut-off point. I don't have 4ws, though and I run my winch off a separate 800mah 2s. Not sure if that would make all that much difference, though. I do have 10 LEDs and a VP dig. What gearing do you have?
04-14-2013, 01:12 PM | #11 |
gears are 21t pinion and 87t spur. Dose the c rating help run times? such as a lower c rating has a slower discharge so the run time would go up. Is that correct? Im looking at turnigy batteries at the moment. What about a Turnigy nano-tech 8400mah 3S 40~80C Lipo Pack?? what kind of run time do you think this would get me?
04-14-2013, 01:21 PM | #12 |
Better than what your getting now lol but since you run a winch you should buy like a 800mah battery for you winch, that would help your run time as well
04-14-2013, 01:30 PM | #13 |
I don't know exactly what the C rating means, just been told that the higher the better. 8400mah ought to be PLENTY! But, that's probably gonna be a big heavy brick.
04-14-2013, 01:35 PM | #14 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: looking for longer run time... Quote:
04-14-2013, 01:39 PM | #15 |
smaller pinion might help a bit but I don't know if you'd be willing to lose a little top-end.
04-14-2013, 02:08 PM | #16 |
I have no top end right now, that's why I was kinda thinking about running 2s with a lower turn motor. I might just buy a big mah 2s and 3s and just mess with it and see what works best. I just didn't want to go money crazy since I don't have any..lol thanks everyone for your input. any other ideas are welcome. |
04-14-2013, 05:38 PM | #17 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
You might want to try a 5000 mili amp battery or more it would double your run times but only if you can spare the extra weight? If you go to a 20 turn motor you won't have as much run time as your current motor because you will be in the throttle more using up the power reserve.
04-14-2013, 07:11 PM | #18 |
Agreed, just get a 5000mah 3s and find a way to stuff it in there. Keep your 2200 in your pocket, jic.
04-14-2013, 07:21 PM | #19 |
I keep 2 2200mah in the rig while up on the trails. Weight is not a problem for me... lol
04-14-2013, 09:03 PM | #20 |
Newbie Join Date: Mar 2013 Location: Central city
I run 16/87 gearing in my wraith with only a 4000mah shortie pack and I can run for 2-3 hours. I'm running a 17.5 brushless setup. I would agree with buying a battery with more mah and maybe drop a few teeth on the pinion.
looking for longer run time... - Similar Threads | ||||
Longer run times... | turtleshuffle | Losi Micro-Rock Crawler | 36 | 06-14-2010 02:28 PM |
longer run times??? | 84socal | Newbie General | 12 | 11-02-2008 12:02 PM |
lipo longer run time? | Dman | Electronics | 4 | 10-09-2008 12:42 PM |
I want a longer run time | zeroskater9111 | Newbie General | 11 | 01-22-2008 09:50 PM |
