04-14-2013, 08:31 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: canada
| castle mmp
ook so here is my problem its a 1 month old mmp 2nd pack thru it in my twin hammers the esc led s flash but it wont do anything esc has not been in water was run once in my basement and made its main voyage outdoors today runnijg 2200 mah 3s oacks on it stock pinon on a tekin roc and ideas anyone |
04-14-2013, 08:50 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: castle mmp
Is it shutting down and then momentarily rearming, then shutting off again?
04-14-2013, 09:15 PM | #3 |
| Re: castle mmp
Also which leds? Green led during forward throttle and red for reverse but no motor action?
04-14-2013, 09:17 PM | #4 |
| Re: castle mmp
all 3 leds light and flash no beeping and the fan does not spin when i first hook up a batt the fan twitchs but thats all # leds flash and do nothing BUT flash the bottom of the case feels warm aswell
04-14-2013, 09:22 PM | #5 |
"Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver." Taken from: http://www.castlecreations.com/suppo...max.html#max13 |
04-14-2013, 09:37 PM | #6 |
| Re: castle mmp
i just tried the esc again the bottom gets warm just sitting there no load on it or anything. as for the RX the i just tried the sr300WP and an sr300 the LED lights but its VERY DIM ive tried a few batteries 2 and 3s and one that literally just came off the charger same thing. the heat coming from the bottom concerns me as ive never noticed this. an ideas as to wtf is up? Last edited by Pegasix; 04-14-2013 at 09:42 PM. |
04-14-2013, 10:08 PM | #7 |
Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| Re: castle mmp
I think i would give castle creations a call and tell them what it's doing and see what they say.
04-14-2013, 10:12 PM | #8 |
| Re: castle mmp
ya im going to call them in the morning and go from there i purchased this 02/19/2013 so im assuming there is some form of warranty
04-14-2013, 10:39 PM | #9 |
Rock Stacker Join Date: Aug 2012 Location: Bellevue
| Re: castle mmp
Is your MMP in sensored mode only and is youe sensor wire in all the way on both ends. I run the MMP and Roc Combo also and my MMP fan goes nuts when the sensor wire comes discunected.
04-14-2013, 11:38 PM | #10 |
| Re: castle mmp
i cant even hook it up to my castle link it wont do anything
04-15-2013, 05:23 AM | #11 |
| Re: castle MMP
I would double check: Bind TX to RX RX connection to ESC (make sure it's tight & not backwards) No shorting of any power wires Good solder connections Read the doc Meatwad linked......... |
04-15-2013, 05:50 AM | #12 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: castle mmp
Three things to try. 1st try to rebind it. 2nd use a bec 3rd make sure you have a good solder joint on the motor wires. |
04-15-2013, 10:28 AM | #13 |
| Re: castle mmp
im running a BEC pro with the mmp my solder joints are good as i am currently running this with a tekin rs until i get the MMP situation sorted out. the RX is working and bound to the radio ive tried it with 2 differant spectrums and my 4pl its still doing the same thing and it smells like burning. the bottom is getting hot and i have contacted castle to see WTF is up
04-16-2013, 11:26 AM | #14 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
| Re: castle mmp
I think that maybe you just got a bad MMP. It sucks but it does happen. I just recently got mine working and I was actually nervous to plug in the battery for the first time because of stories you read but so far so good. Hope you get it sorted out soon. |
04-17-2013, 11:00 AM | #15 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Re: castle mmp
Castle is great to deal with, send a message to them and they get back quickly. I deal with Charles...great guy. |
