04-20-2013, 12:34 AM | #1 |
Newbie Join Date: Dec 2012 Location: Canby OR
| 4PL help please
Hello all. I'm trying to setup my 4pl to use a dig on my wraith. I have figured out how to make the dig work off the slide switch. however. I need to adjust the servo posi value on each of the 3 switch positions to keep the servo from melting down. I adjust 1 value to be right but when I move the switch to adjust another. The first resets. Can anyone point me tords a thread that has delt with this issue. Or can anyone with knowledge with the 4PL help me out.
04-21-2013, 11:03 AM | #2 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: 4PL help please
Your guide: Futaba 4PL Setup, Tips, Tricks & Help If you try the search button (advanced) on 4PL you would have found this thread below your own ..... Not meaning to burn you .... but every question you can come up with is probably asked before ... so ... the searchbutton is your best friend. Harley is a Futaba Team driver, and can help you out with Futaba issue's |
04-21-2013, 03:18 PM | #3 |
Newbie Join Date: Nov 2009 Location: Portland
| Re: 4PL help please
I did look through that thread. I went through like 60 pages. So I guess I just flat missed that link. I think the link I clicked on took me to the 14th page though. Thanks for the smack on the back of the head haha. We all need them from time to time
04-21-2013, 09:56 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: 4PL help please
I think you need to set the middle point first (ie neutral rear free wheel), then use EPA to set the upper (ie 4wd) and lower end points (ie Rear lock). Because it work like steering, if you set the trim on the left turn first, once you move the neutral point the left point will followed.
04-22-2013, 05:03 PM | #5 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
| Re: 4PL help please
Put the dig on DT-3 on mine. Seems easier to use while driving. Just use the thumb that is already on it or nearby. First programmed that switch to function as Ch 3 then set the forward or rearward push value at ~30. Forward push from neutral gets front dig. Push rear once to get back to 4wd. From there a reaward push gets you rear dig. Back to the 'middle' position puts it back in 4wd. Works just like a 3 position toggle. Of course I got all the info from Harley's thread! Last edited by anuthabubba; 04-22-2013 at 05:09 PM. Reason: Credit due. |
4PL help please - Similar Threads | ||||
help with 4pl | customforlife | Electronics | 4 | 12-30-2012 01:30 PM |
New 4pl RX? | Bukwylde | Electronics | 6 | 09-15-2012 02:00 PM |
