04-20-2013, 02:07 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
| What armature will fit?
I have a 27 turn torque master expert 540. Wire came loose at the termination point on the armature. Need a replacement armature, either a 27 or 35 turn. I would get one from HH, but shipping is the same price as the part to Canada. Are there other brands that will fit the casing? Can't get anything but a integy 35 turn lathe motor locally.
04-20-2013, 02:11 PM | #2 |
| Re: What armature will fit?
For can size, pretty much anything fits. On comm size, some end-bells have issues with 10mm comm's. What diameter is your current comm.? If it's less than 10mm, almost anything fits. I will defer to Holmes or Eddie0. |
04-20-2013, 02:34 PM | #3 |
My cousin is trading me an 35t integy motor. Putting the integy armature into the HH can.
04-20-2013, 09:47 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Can't you resolder the wire. I would try to repair the handwound arm before I put a junk integy part in a good motor.
04-21-2013, 07:55 AM | #5 |
| Re: What armature will fit? It's not a pro hand wound armature. It's just three bent tabs that connect the wires. I don't think it would have broke if it was one of his hand wound armatures.
04-21-2013, 05:07 PM | #6 |
I'd like to add that the wire came loose when staple found it's way into the motor. It wasn't a motor quality issue. I'm just going to keep the can and order a new armature when I order a new motor one day.
What armature will fit? - Similar Threads | ||||
HH armature swap | KnoJa | Electronics | 14 | 10-18-2011 01:21 PM |
5 pole armature | EGRESSor | Electronics | 4 | 09-29-2005 07:42 PM |
