04-21-2013, 09:21 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: okanagan BC
| fxr problem
i have a brand new fxr and 35 t motor, the thing will run good and once in awhile when i let off throttle and go to start again, it will hesitate, or i have to blip full throttle to get it to......gear mesh is ok, i broke in motor on 5 volt for 3 min.....im stumped, it doent always do it but when it matters ie: on a ledge where control is needed it sucks.... i should have got the brxl, i have one in my 2.2 and it rocks over this fxr i know its most likely a simple oversight but anyone able to shed some light..... |
04-21-2013, 10:04 PM | #2 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: fxr problem
Did you use the Hot Wire set up ??? I think there is a throttle delay in the settings...you need to adjust that |
04-21-2013, 10:59 PM | #3 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: fxr problem
Look at the forward/reverse delay setting
04-21-2013, 11:05 PM | #4 |
| Re: fxr problem
ya i dont have a hot wire....looks like im gettin one tomorrow.....ah that sucks its sealed inside my waterproof container.....i only set up cutoff, drag brake and such....i will check it out tomorrow, thanks for the imput...i didnt know there was a delay in there....why would it be on by default, i like instant forward reverse as most people i know, that should be default
04-22-2013, 02:59 PM | #5 |
| Re: fxr problem
check out the fxr manual, its real easy to switch to instant forward to reverse by pressing a few buttons. should take about 5 min. |
fxr problem - Similar Threads | ||||
fxr problem please help | CrAwLeR13 | Electronics | 11 | 07-21-2010 06:24 PM |
FXR Problem | Entropy98 | Electronics | 10 | 01-23-2010 03:00 PM |
Problem with FXR | dman1101 | Electronics | 4 | 12-15-2009 03:27 PM |
FXR Problem | tjontherox | Electronics | 4 | 09-03-2009 01:40 PM |
FXR problem | xblade | Electronics | 8 | 03-21-2009 12:03 AM |
