04-23-2013, 10:35 AM | #1 |
Newbie Join Date: Mar 2013 Location: Fremont
| axial tx antenna wire came off board.
I have axial Ax-3 tx and was running it one day and the range was terrible. Everything on the outside appeared ok. I pulled it apart and sure enough the antenna wire had come out of its soldering hole. I am no master electrician but I know my way around a solder gun. Heated the solder real quick, reattached wire and presto it was fixed. Until I tried to use it again atleast. Did help range slightly but still only good for 20 feet. There are 2 identical spots on the board for the antenna. 1 on the outside and 1 on the inside right next to it with a small pin hole in it. I attached wire to outside location. Wire was not broke off and I did not put any more solder on . Any ideas or tips would be extremely helpful. Thank you in advance. Last edited by Crawlerjedi; 04-23-2013 at 02:46 PM. |
04-23-2013, 11:47 AM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Is it a coaxial antenna? (2wires, one inside the other) if so, its a tougher task making the repair. EDIT: You meant AX-1 radio, right? Last edited by monkeyracing; 04-23-2013 at 11:52 AM. |
04-23-2013, 11:59 AM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Salina
| Re: axial tx antenna wire came off board. |
04-23-2013, 02:40 PM | #4 |
sorry i meant Ax3 2.4 ghz radio transmitter. Watched the video. It really only covered receivers and did not really help much. Need to know if there is a special way to solder the antenna wire back to the board. I do believe it is a coax cable.
04-23-2013, 03:51 PM | #5 |
axial tx antenna wire came off board. - Similar Threads | ||||
DX3E antenna wire | Garry | Electronics | 7 | 02-25-2011 10:44 AM |
Need some antenna wire | losikid | Electronics | 4 | 11-09-2010 07:15 PM |
Antenna wire | Rubiconmike1 | Electronics | 3 | 11-02-2009 10:20 PM |
Antenna wire broke off:( | MiddleT | Electronics | 5 | 05-18-2009 08:23 AM |
Anyone replaced the metal antenna with an antenna wire? | greenone | General Crawlers | 6 | 01-31-2006 09:17 PM |
