04-23-2013, 06:38 PM | #1 |
Quarry Creeper Join Date: Aug 2004 Location: salt lake city
| Fried my B1R
I have a tekin B1R in My Mrc, I hooked up a team brood Frenzy motor. and it fried my B1R I am sure I had it set up right. Tekin says the B1R has no motor limit other than it has to be a 350 size motor. Any advice would me great. |
04-23-2013, 06:39 PM | #2 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Did you let the wire leads touch?
04-23-2013, 06:40 PM | #3 |
| Re: Fried my B1R
No, anyone run this motor?
04-23-2013, 07:05 PM | #4 |
Rock Crawler Join Date: Dec 2008 Location: Displacement
| Re: Fried my B1R
The motor was most likely not the cause of the esc failure. Do you have a Bec installed? I've been told that the bec circuitry in a B1r is very sensitive to crawling applications and requires the use of an external one to meet the demands of 2.4 receivers and high servo loads. Otherwise it might fail, sinking the whole ship. |
04-23-2013, 07:48 PM | #5 |
| Re: Fried my B1R
I have heard of that with a B1R, What if I were to run a FXR would I still need a BEC?
04-23-2013, 08:26 PM | #6 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
I always recomend a BEC. Always. The fxr is a 1/10 esc and thus more robust so it will handle when your truck gets bound up between rocks better. Always run a BEC and always run a cap with the esc. Just my $.02 That being said I've been running a B1R with a castle BEC since January without issue. Sent from my iPhone using autocorrect Last edited by happymachinist; 04-23-2013 at 08:28 PM. |
04-23-2013, 09:27 PM | #7 |
| Re: Fried my B1R
X2 on what Happymachinist said. Yes, I would still recommend using a bec with an fxr, even with it being a 1/10 esc. The B1r is also good, but a bec is definitely a must. |
04-24-2013, 05:41 AM | #8 |
| Re: Fried my B1R |
04-24-2013, 07:25 PM | #9 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Fried my B1R
What battery were you using? I've been using a B1r for about a year and I went and resoldered it last month and when I plugged it back in it started smoking and now it's got a black spot on it and doesn't work... I did take off the wire posts and the case but that shouldn't have affected anything...
04-24-2013, 08:06 PM | #10 |
I wanna be Dave Join Date: Aug 2007 Location: *
| Re: Fried my B1R
Are you guys using the external capacitor? If not that would cause certain death of the ESC. |
04-25-2013, 10:18 PM | #11 |
| Re: Fried my B1R
I have ran without a bec for years, with a hitec robotic servo, I direct wired it. kinda like a bec. with a hand wound 35t motor. yes I have also run the capacitor, I run a 2 cell thunder power 1350 batt. this all ran great for years but my motor is getting weak and I wanted to try something else. when I wired up the brood motor the B1R fried. I have gone back to my old 35t motor for the time being, (1.9 comp crawling is still be where I live). I have just wondered what what people thought about what would have gone wrong. and who has ran the brood frenzy motor. thanks to all that have taking the time to answer this thread. you have been most helpful. |
Fried my B1R - Similar Threads | ||||
B1r | jason yates | Electronics | 5 | 05-11-2009 08:01 AM |
fried rx=fried crystal too? | pantablo | Electronics | 0 | 07-16-2008 02:46 PM |
