04-24-2013, 01:32 PM | #1 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| Glitching, RX to blame?
Hey All, i have been having a little glitching the last couple times i ran my truck, i'll give you a rundown of what's in it and then explain the issue. The truck, is a xr10 switch, 35t Br00d creeps, dual mamba sidewinders sammiched, cc 10a bec, savox 1230 servo, 4pl with 2106GF RX Ok so now for the issue, it's a pain because it's not consistent, once every 10-15 minutes, the truck will just drive on it's own, and it does this in various ways, the radio is non responsive during these episodes... Each time it lasts about 3 seconds One time it was upright on flat ground, it just drove at about 10-20% throttle another time it was upside down, only the front ran, same thing 10-20% throttle then back to normal A couple times i had minor glitching on the servo, just a little wiggle 1/2 second, but throttle died out during that time and one time the whole truck just went non responsive, but there was still power because the servo was whining. i cant recall if i had dig on or anything So, my troubleshooting has given me these observations: One of the times i looked at the TX while it was happening and it had no action on channels 2 or 4, so i have ruled out the tx sending bad signals The ESCs do not re-arm, so i don't believe it's a power connection issue My RX is powered by the ESC, so it's not a BEC issue So the only 2 left would be the servo, or the RX, and i just don't see how the servo could cause this... so, i think i have nailed it down, but won't have a chance to swap out the rx and test it til tomorrow, just wanted to bounce this off the pros out there to make sure i am headed in the right direction. EDIT. i should also add, last night i ripped apart all my elects, make sure nothing was touching or grounding out, and stuck it all back together, and it made no effect. Last edited by T3rry; 04-24-2013 at 01:38 PM. |
04-24-2013, 01:35 PM | #2 |
RCC Addict Join Date: May 2011 Location: Utah County
Yes you need a bec. Haha jk. No clue dude. Sent from my SCH-I535 using Tapatalk 2 |
04-24-2013, 01:41 PM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Glitching, RX to blame?
A bad servo can muck up the system. I had a shift servo go, even with BEC, nothing worked right. It was glitchy and unresponsive. It "COULD" be a bad servo, or the servo is starting to fail. Do you have a spare servo to test?
04-24-2013, 02:58 PM | #4 |
| Re: Glitching, RX to blame? i do not, but i do have an RX, so i think i will try that first (the part that sucks is i have my rx (and servo) soldered in, so it's gonna be a PITA either way, oh well, thanks for the response.
04-25-2013, 08:38 AM | #5 |
Rock Stacker Join Date: Nov 2011 Location: clarskville/ but now back in Ohio
I had the same problem and I figured it was the esc but after spending a hour or so on the phone with axial, they figured out that my rx/tx was bad sent me a new one and boom all is good. So I'd change out the rx/tx
04-25-2013, 08:44 AM | #6 |
| Re: Glitching, RX to blame? easier said than done, i am not prepared to throw a $300 tx in the trash I swapped out the RX last night and will be testing it today, in about 3-4 hours i'll be on the rocks to give it a test.
04-25-2013, 02:05 PM | #7 |
got out and played today for about 45 minutes and did not have any issues, lets hope i licked it, bad RX.
04-25-2013, 02:15 PM | #8 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Glitching, RX to blame? |
Glitching, RX to blame? - Similar Threads | ||||
Well I blame you lot! | rikstr | Chit Chat | 10 | 05-18-2009 06:28 PM |
glitching | kingbasher | Newbie General | 8 | 07-17-2008 10:44 PM |
your all to blame...and some simple Q's for the hardcore guy | Cutter | General Crawlers | 9 | 08-15-2004 01:07 AM |
