04-27-2013, 09:53 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: sweden
| Gearing for an 35x36mm outrunner ?
If i whant to put an outrunner that has an 35x36mm stator and 850kv In a hsp pangolin/ax10 what gearing would work on 2-3s lipo ? I have an old sidewinder esc (the first version of the 1/10 scale sidewinder) Witch software vetsion works best for crawling ? There are like 10st to choose from ? |
04-28-2013, 04:44 PM | #2 |
| Re: Gearing for an 35x36mm outrunner ?
Gear it as low and slow as possible for best startup. Not sure of any software that has best startup.
04-29-2013, 05:32 AM | #3 |
For Castle ESC's, I like firmware 1.28. Some of the newer versions don't seem to work as well as the older ones. You can then use a Castle Link to set a "belly" in the throttle curve so when you 1st start to move the trigger, the ESC gets a small signal. |
Gearing for an 35x36mm outrunner ? - Similar Threads | ||||
outrunner? | muddinscx | Electronics | 8 | 10-14-2011 11:56 PM |
Outrunner | stack'o'rocks | Electronics | 2 | 10-16-2009 05:14 PM |
Which outrunner?? | totalxbadass | Electronics | 3 | 04-13-2007 04:26 PM |
Outrunner help | robvbro81 | Electronics | 2 | 02-03-2006 07:45 PM |
