04-28-2013, 08:32 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| tekin fxr?
I went to reset some things on my fxr and the buttons on it are not working. Mode button will let me go to program mode and then i cant get it to do anything else. Any ideas on a fix, or do i go buy a hotwire? I lost mine or it took legs, thats how i programed it the first time when i bought it. Thanks |
04-28-2013, 10:02 AM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: tekin fxr?
If you go to the settings with the mode button, then you need to turn it off then back on to run it.
04-28-2013, 10:03 AM | #3 |
| Re: tekin fxr?
Wait, is increment not working? Because that would be different.
04-28-2013, 04:41 PM | #4 |
| Re: tekin fxr?
Mode button works
04-29-2013, 05:34 AM | #5 |
| Re: tekin fxr?
Check to see if you have dirt holding a button or there is moisture inside the case.
04-29-2013, 04:41 PM | #6 | |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: tekin fxr? Quote:
OP, if you press MODE once to get into the settings, you should be able to press INCR to start adjusting them. | |
04-29-2013, 10:17 PM | #7 |
| Re: tekin fxr?
I went out and got a hotwire.. much easier. Works fine, buttons still dont work.
04-30-2013, 05:26 AM | #8 |
| Re: tekin fxr? |
tekin fxr? - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
