Thread: holmes hobby torque master beeps
Old 04-29-2013, 07:48 AM   #1
Default holmes hobby torque master beeps
I have the torque master and 55t rockstar . I was crawling and the motor came unplugged and now it just beeps no throttle the steering still works anybody got any ideas. Thanks
crawler 129 is offline   Reply With Quote
Old 04-29-2013, 12:09 PM   #2
Default Re: holmes hobby torque master beeps
1-You mean you have a Holmes BR-XL ESC?? A Torqumaster is a motor, not an ESC.
2-Do you get any lights/LED's on the ESC?
3-Did you recalibrate the ESC?
Basic troubleshooting... Castle Creations | FAQ: 1/10th Scale Products ....
Holmes BR-XL manual... http://holmeshobbies.com/Common%20fi...ion%201.08.pdf
Charlie-III is offline   Reply With Quote
Old 04-29-2013, 12:59 PM   #3
1. Yes
2. No
3. I think that I plugged the motor back in on the negative side so it was a double negative I think it is fried I tried another battery with no luck thanks for the reply.
Old 04-29-2013, 02:21 PM   #4
Originally Posted by crawler 129 View Post
1. Yes
2. No
I'm guessing you mean you plugged the battery into the ESC output (motor) side?
If so, in the future, if you use connectors on both sides of the ESC, put a male connector on the battery/input side and a female on the motor/output side. This way you CAN'T plug things together wrong.
Old 04-29-2013, 05:22 PM   #5
install spare esc works fine . Thanks
holmes hobby torque master beeps - Similar Threads
Holmes Torque Master jlobato Electronics 6 08-21-2012 06:12 PM
Holmes Hobby Torque Master Mini 01tj Losi Mini-Rock Crawler 20 04-02-2011 02:16 PM
Holmes mini torque master Drvnbeing Electronics 2 04-22-2009 09:52 PM
