05-01-2013, 11:53 AM | #1 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
| High voltage servo wiring?
I currently have this HS-5645MG - Hitec RCD servo that is rated at 6v max. I have a BEC run to my receiver set at 6v. Lets say if I upgraded to this HS-7940TH - Hitec RCD servo that is rated at 7.4v max. How would I wire this up? I cannot run my BEC at 7.4v to the receiver can I? I am using a flysky fs-gt3b radio/receiver. Am I even supposed to run the receiver at 6v. Sorry for all the questions but as you can tell I am new to using a BEC and I could not find the max rating on this receiver in the very vague manual. Thanks |
05-01-2013, 11:57 AM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: High voltage servo wiring?
Use this bypass cable to power the servo. Keep the ESC BEC around 6v to power the receiver. Holmes Hobbies LLC |
05-01-2013, 01:14 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: High voltage servo wiring? |
05-01-2013, 01:29 PM | #4 | |
Rock Crawler Join Date: Feb 2012 Location: OC
| Re: High voltage servo wiring? Quote:
Exactly!!! Or instead i wire mine (sodier) directly to the BEC dont use the tan wire (signal wire). | |
05-01-2013, 03:25 PM | #5 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
That little cable makes it so much more simple and it makes sure your receiver doesn't get roasted. I run them on everything. | |
05-01-2013, 05:02 PM | #6 |
The FlySky receivers are not high voltage.
05-01-2013, 06:58 PM | #7 |
05-01-2013, 08:57 PM | #8 |
This is another option to run only the steering servo from your BEC. This one is plug and play so it is great if you don't want to do any soldering. No Brainer BEC |
05-02-2013, 06:35 AM | #9 |
Thank you guys for your replies and information, just what I needed to know. Have a good one everybody!! |
05-02-2013, 11:59 AM | #10 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
I just use a servo Y with the signal wire pulled out.
High voltage servo wiring? - Similar Threads | ||||
High Voltage Mini Servo? | mrG | Electronics | 3 | 07-18-2010 11:50 PM |
Wiring high voltage servo? | meatmonkey | Electronics | 6 | 07-18-2010 08:54 PM |
high voltage servo? | driftin90 | Electronics | 10 | 09-23-2009 08:33 AM |
Wiring a voltage regulator for 2nd servo | teamtom | Electronics | 1 | 05-19-2006 12:10 PM |
Wiring a voltage regulator for 2nd servo | teamtom | Tamiya Clod Buster | 0 | 05-16-2006 08:01 PM |
