11-27-2009, 09:01 PM | #121 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| I reinstalled switch. This is how I wired it with a 10k ohm resister. |
11-29-2009, 08:37 AM | #122 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
If I understand your wiring correctly, here is what I think you have....which won't work. When you press SW1 you're simply shorting out the 5V on the board. Can you show me exactly how the stock 3rd channel switch was wired to the board? Jay |
11-29-2009, 10:56 AM | #123 |
Post#119- The switch was where you drew the 5v and grounds with the arrows, the botton hole which is ground. I did wire the switches like the diagram in post #122. |
11-29-2009, 01:26 PM | #124 |
| This is where the orignal switch was wired the 5 holes in the board. The top and bottom held in the switch which are also grounds. The reason I should you R19 because I thouht it was the input. I'm not sure what the input is located. Thanks for your help. |
11-29-2009, 01:55 PM | #125 |
| Better picture. First time adding text to picture. Took me a while. The bottom hole is ground. The top 2 holes are also ground. The hole I soldered the wire to is 5 volts and the hole above that is 5 volts also. Last edited by SDheavymetal; 11-30-2009 at 10:23 PM. Reason: added last to lines |
11-30-2009, 09:57 PM | #126 |
One of the original switch terminals should go to the input. Makes sense that the other two are 5V and ground. Jay |
