05-05-2013, 06:59 AM | #1 |
Newbie Join Date: Apr 2013 Location: Uk
| Going brushless with lipos
Ive got two of these Turnigy nano-tech 5600mah 2S2P 50~100C Hardcase Lipo Pack (ROAR APPROVED) I'm going to double them up so I'll have 4cell, what's the best way to do this I've got a traxxas y- lead connector will this work? There be going into my summit! |
05-05-2013, 07:09 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Going brushless with lipos
Do want to double the voltage or capacity?
05-05-2013, 08:51 AM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Casper
For a Summit, I believe they need double the volts. Essentially, runs on 4s.
05-05-2013, 08:59 AM | #4 |
Ok then you either need to buy a series harness or make your own. For the series connection, the two batteries are connected going from one battery to the other, positive to negative, negative to positive. Now you would take the negative lead from batt #1 and the positive lead from batt #2 and solder on your female connector.
05-05-2013, 05:06 PM | #5 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
You may want to provide an illustration. Your initial description is a recipe for starting a fire if not read very carefully. i |
05-05-2013, 05:44 PM | #6 |
Point taken
05-06-2013, 01:27 PM | #7 |
This is what ive got so will the work? TRAXXAS SERIES Y-LEAD BATTERY CONNECTOR 3063 I've got two 2cells and won't to make it into 4 cell |
05-06-2013, 01:35 PM | #8 |
Yes that will work.
