05-12-2013, 05:10 PM | #1 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
| LEDs w/o control board
So my hobby shop had some axial LEDs that didn't have the control board for 10$ so I said hey and got it. What I'm asking is how can I use these light with my receiver? Because I hooked up the white and they didn't work and my plan was to just plug them in the aux on my receiver.
05-12-2013, 05:17 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: LEDs w/o control board
First, hope you didn't already burn them. Next, research. Find out what voltage they run at. I don't know, or I'd tell you. Probably under 5V though. Then use an online calculator to figure out how to wire them the way you intend.
05-12-2013, 05:18 PM | #3 |
I know the reds and the whites use diff V though. Not sure what it is but the red is lower.
05-12-2013, 05:20 PM | #4 |
Alright thanks ill see what I can do
05-12-2013, 05:31 PM | #5 |
Start with low volts (1 AA) and see what happens. A DC power supply is recommended but you'd need to have a good way to measure temps, also. I'm sure someone on here knows exactly what V those LEDs run at.
05-12-2013, 07:23 PM | #6 |
I think you will find all the info you need to get your LEDs going in here: How to wire LEDs If not, ask away and I will do my best to answer. |
LEDs w/o control board - Similar Threads | ||||
Leds | solly98 | Axial SCX-10 | 2 | 01-02-2013 03:58 PM |
little help with leds please!!! | lordjasper1988 | Losi Micro-Rock Crawler | 5 | 03-09-2011 05:14 PM |
Super Board Killed this board. | Bart bender | Kyosho Crawlers | 2 | 04-22-2010 11:34 AM |
LEDs | ABOW | Electronics | 0 | 09-21-2009 04:17 PM |
