05-14-2013, 10:55 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: ...---...---...---...---
| No drag brake going forward.
I have 2 sets of micro sidewinders that I'm having the same issues with, one bec is set to 6.0 volts and the other is set to 7.4 volts. I am running duel micro sidewinders smashed with a bec set to either 7.4 and 6.0, the issue I'm having is when going forward and let off the throttle it coasts to a stop, but in reverse when you let off the throttle it stops immediately, I've changed electronics to dual fxr's and it still happened just very intermittent, I've changed out the motors and still the same thing. I run a rutaba 4pk and I am wondering if it is a radio setting issue, or a esc setting issue, or heck even a motor issue, I had the motors rebuilt by Holmes at the start of the season, and it all worked flawlessly up until about 4 months ago (4 comps). Any help or suggestions would be much appreciated. Last edited by Stick Crawles; 05-14-2013 at 10:58 AM. |
05-14-2013, 12:55 PM | #2 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
| Re: No drag brake going forward.
How old is your 4pk? It may be time to have it gone through and freshened up. I know Grimreeper had a problem with his a while back. Every now and then his throttle would drift off of neutral, even with the radio sitting idle. Or check your throttle trim. It may be off just far enough to release the drag brake, but not far enough to spin the motors. |
05-14-2013, 12:59 PM | #3 |
What he said...need to confirm that your radio is finding a good neutral position. There is an option in the menu of the 4PK for ADJST...try that...it's fairly self explanatory. Also...are you calibrating the ESC's to the radio each time you're swapping between the different setups? If you're not doing this then the ESC's might not be seeing a good neutral signal from the 4PK. Just checking... |
05-14-2013, 01:17 PM | #4 |
Ive used the 4pk for the last 3 seasons with no issues and it only has something like 20-30 hrs on it. I'll check out the throttle settings and see if that helps. Anymore suggestions?? Any and all are appreciated. |
05-14-2013, 01:31 PM | #5 |
Correction there is only 13hrs 10min on the radio.
05-14-2013, 02:57 PM | #6 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Try programing the esc's independant of each other. Only plug one lead in at a time, then the other. I remember having some issues setting my trottle all at once one time. I just read your discription, and now I am a bit more stumped. If it is both sets of Mamba's then I really don't get it. Still worth trying to program each ESC independant of each other to see if that helps. What neutral band did you set the esc's at? Last edited by RickM; 05-14-2013 at 03:01 PM. |
05-16-2013, 02:59 PM | #7 |
Got it fixed, changed the throttle settings in the adjust menus and it woked, thanks for all the suggestions.
No drag brake going forward. - Similar Threads | ||||
Castle / AE-2 Drag Brake and Brake Power | ik632 | Electronics | 0 | 04-08-2012 07:47 AM |
Does drag brake... | Krawler23 | Newbie General | 3 | 02-25-2012 08:14 PM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
Throttle / Drag Brake / Brake Question | phatchantz | Newbie General | 5 | 05-19-2008 11:57 AM |
Front Dig, Which is preferred? Brake or no brake? | USATorque55 | Tamiya TLT Crawlers | 10 | 08-29-2006 12:18 AM |
