05-16-2013, 07:56 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| Motor getting hot
ok a have used the same motor/esc/spur/pinion setup for about 4 months now and it never got hot before and now all a sudden after five minutes of running not full throttle but about half throttle when you stop it and feel it it is super hot i mean really hot and i dont know why this would just know start to happen. Anyone know why this would all of a sudden start happening? |
05-16-2013, 08:37 PM | #2 |
| Re: Motor getting hot
Debris inside the motor? What maintenance have you done on it lately?
05-16-2013, 08:44 PM | #3 |
I just cleaned it out yesterday.
05-16-2013, 09:30 PM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Did you oil the bearings after you cleaned it ?
05-16-2013, 09:31 PM | #5 |
Yup
05-16-2013, 10:00 PM | #6 |
Did it start getting hot after you cleaned it, or before? How did you clean it?
05-16-2013, 10:04 PM | #7 |
Got hot after I cleaned it. Took off end and the thing that spins out took a toothbrush to get all foreign material out of can oiled all bearings and put back together.
05-16-2013, 10:07 PM | #8 |
Then it sounds like you need to take it apart again and make sure you put it all back together properly. Pictures of the setup would be helpful.
05-16-2013, 10:21 PM | #9 |
It's been a long time since I've been inside a brushed motor case...did you shove a magnet around with that tooth brush ???
05-16-2013, 11:36 PM | #10 |
Rock Crawler Join Date: May 2007 Location: Arnold
Sounds to me like you didn't get the timing set back to "0".
05-17-2013, 06:33 AM | #11 |
| Re: Motor getting hot |
10-17-2013, 08:19 PM | #12 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
If it's not marked on the can 0* how can i be sure to put it back or where zero may be?
10-17-2013, 08:21 PM | #13 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
On most motors, zero is between the mounting holes on the bottom, so you can eyeball it to line the endbell screw to be dead center between the holes. Later EddieO |
10-17-2013, 08:22 PM | #14 | |
| Re: Motor getting hot Quote:
540 Brushed Motor Care, Installation, and Troubleshoot | The Search for Power Good read on a rainy afternoon too. | |
10-26-2013, 08:35 PM | #15 |
That pic was what I needed thank you. I started changing changing parts around mixing cans and armatures and got lost. 0* timing is what Im after then, in my wraith since its a CCw turrning Right? |
10-26-2013, 09:30 PM | #16 |
Some wraiths use ccw... Some use clockwise. Test and find out... Later EddieO |
10-26-2013, 09:52 PM | #17 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
4 months old and heat issues. Sounds like a great excuse to pick up a new motor.
10-26-2013, 11:29 PM | #18 |
Pebble Pounder Join Date: Mar 2004 Location: Calgary AB Canada
Motor getting hot - Similar Threads | ||||
Motor getting hot | EricTheRitt | Axial Wraith | 10 | 06-11-2012 07:48 PM |
How hot is too hot for the motor? | Mr. Ed | Losi Mini-Rock Crawler | 4 | 06-13-2010 11:09 PM |
motor temp - how hot is too hot? | wicked4x4 | Newbie General | 16 | 03-18-2010 09:49 AM |
Hot Motor | Nish | Electronics | 12 | 05-20-2009 04:55 PM |
Motor Getting hot. | Moondust1950 | Electronics | 2 | 03-17-2007 08:51 PM |
