05-21-2013, 04:44 PM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
| Tekin Fxr 3s problem?
My ESC and motor get super hot when I run a 3s in my Wraith, not even after 5 mins of running it? It gets glitchy and jumps around? It has a 87t spur and 13t pinion with the stock 20t so I don't think gearing is the problem? No heat or glitching when I ran 2s? Any help will be super appreciated, thanks in advance. -Trent |
05-21-2013, 04:50 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
Are you having any binding issues in the transmission or axles? Are you running a external bec with your servo....that can create extra heat. Last edited by jeepster73; 05-21-2013 at 04:53 PM. |
05-21-2013, 04:53 PM | #3 |
| Re: Tekin Fxr 3s problem?
I would check in the Wraith section....a 20T motor & that gearing sounds high to me. High gearing (speed gearing) leads to a hot motor. Yes, double check drivetrain binding & pinion/spur gear mesh, really sounds overgeared for that motor on 3S LiPO though. |
05-21-2013, 05:10 PM | #4 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Although I have a different esc, I'm running 14/87 on my wraith with a 35t tekin motor on 3s, my temps have been great so far..so it may b an overgearing issue, but the glitching is most likely from not having a bec.. -sent from my smarter than me phone |
05-21-2013, 05:11 PM | #5 |
sounds like the problem is the 20t motor. throw in a 35t or higher to test it, heat problem should go away. also I believe the specs for the FXR are 35t or higher on 3s |
05-21-2013, 05:21 PM | #6 |
| Re: Tekin Fxr 3s problem? |
05-21-2013, 05:24 PM | #7 |
I really don't think its the motors fault either.
05-21-2013, 06:27 PM | #8 |
alright thanks guys! ill stop by my lhs tomorrow and pick up a bec. thanks! |
Tekin Fxr 3s problem? - Similar Threads | ||||
Tekin FXR reverse problem | cr01 | Electronics | 3 | 06-27-2012 10:46 PM |
tekin 55t fxr problem | fascar228 | Electronics | 20 | 04-25-2012 02:13 AM |
Tekin fxr problem | ax-10 crazy | Electronics | 3 | 11-16-2010 09:27 PM |
Tekin FXR problem | Phylodog | Electronics | 22 | 02-13-2010 08:02 PM |
Problem with Tekin fxr esc | HELLSUNICORN | Electronics | 16 | 05-12-2009 12:18 AM |
