05-25-2013, 12:54 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
| What do you do when a Hitec 7980 and Castle BEC Pro aren't enough?
As title really bought the best gear I could find, thinking it would do the job with ease on my big scale crawler, but it stalls out with ease. Need and even stronger steering setup. Anyone got any ideas? I'm totally stumped Thanks. |
05-25-2013, 01:13 PM | #2 |
| Re: What do you do when a Hitec 7980 and Castle BEC Pro aren't enough?
What is the CC BEC set to?? If stock, it's under voltage for the 7980. Get a Castle Link & up the voltage. Why do you say, "It's not enough"???? |
05-25-2013, 01:35 PM | #3 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
1/4 scale servo on a 3s.
05-25-2013, 01:55 PM | #4 |
| Re: What do you do when a Hitec 7980 and Castle BEC Pro aren't enough? |
05-25-2013, 02:03 PM | #5 |
You have as much torque as you are going to get in that size package. You can double up with another 7980 or you can look at the bigger options. Compare servos here: All RC Servos - Servo Database That link should have them organized by torque but if not just click on torque at the top.
05-25-2013, 02:09 PM | #6 | |
| Re: What do you do when a Hitec 7980 and Castle BEC Pro aren't enough? Quote:
I wanted to know why the OP thought it was underpowered. I was not asking your thoughts. Frankly, if a single 7980 does not do it...there are many other issues....do you agree?? Sheesh, I have enough issues with a 7950 or a external powered BLS197(?) in a 2.2 rig. BTW, a 7980 is already larger than most 2.2 rigs can handle "standard", if a 7980 is not enough (already making mount adjustments), why go even bigger???!!! | |
05-25-2013, 03:02 PM | #7 | |
05-25-2013, 03:33 PM | #8 |
Hi guys, thanks for the replies The CC BEC is set to 7.5volts, so hopefully it's getting enough juice. Thanks for the link for all the different servos, I'll have a look through it and see if there's anything that might do the job. I didn't want to go any bigger servo wise, but it's looking like I might not have any choice. As far as the truck goes, it's got an 18" wheelbase, 40 series wheels and tires, 1/8 scale brushless system, Summit trans, Twinforce axles, solid body with exo cage....And weighs ALOT, lot 32.5lbs. All custom chassis etc, taken along time to build. It's nicknamed Heavy Duty. |
05-25-2013, 04:04 PM | #9 |
Quarry Creeper Join Date: Feb 2011 Location: Germany
Buy a Hitec HS-1000SGT Torque @ 11,1 V : 84,0 kg Torque @ 14,8 V : 110,0 kg |
05-25-2013, 04:05 PM | #10 | |
RCC Addict Join Date: Aug 2011 Location: Elkhart
And hope you find a servo to fit your needs. I'm not schooled on anything bigger than 7980.. Good luck !! | |
05-25-2013, 04:08 PM | #11 |
32+lbs?! wow man, a couple 7980's per front wheel perhaps?
05-25-2013, 07:30 PM | #12 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Really 32lbs ???? Pictures of that beast please........ |
05-25-2013, 07:30 PM | #13 |
05-25-2013, 07:35 PM | #14 |
05-25-2013, 07:42 PM | #15 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Pictures please.....
05-25-2013, 07:42 PM | #16 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
05-25-2013, 08:46 PM | #17 |
Rock Crawler Join Date: May 2012 Location: Australia
How do you have your bec wired? Do you directly power the servo? So plug bec into servo + and - and signal to rx? Or do you use the bec to power the rx then left over power goes to servo? I run a 7980 on either end of my 1/8 crawler and use a bec for each servo. I run the bec straight to the servo. It's a lot better for getting most power. It's worth checking how you have it wired. |
05-26-2013, 12:42 AM | #18 |
You might as well throw a hydraulic pump on there and go fullhydro steering at that weight You can try a gear box SPG400A-45 Standard Rotation |
05-26-2013, 01:18 AM | #19 |
05-26-2013, 05:22 AM | #20 | ||||
Quote: Quote:
I'll sort out some pics for those who want them | ||||
What do you do when a Hitec 7980 and Castle BEC Pro aren't enough? - Similar Threads | ||||
Castle BEC w/ HH BR-XL and Hitec Servo | AsILayDying | Newbie General | 2 | 08-29-2011 03:54 PM |
Castle BEC Pro | JeremyH | Electronics | 7 | 08-23-2009 01:10 AM |
