05-26-2013, 05:03 PM | #1 |
Newbie Join Date: May 2013 Location: Kountze
| More wheelspeed for my crawler king
Hey guys i jus purchased the holmes hobbies waterproof brushed esc, and so far i dont see any difference than the stock esc besides the drag brak but the torque is still about the same and everything. Now my question is if i change the fireball 55t to a holmes hobbies 35t motor (dont kno which one yet) will i see way more performance out of the truck? I also need to switch to lipo but i want to get by with jus the motor swap.
05-26-2013, 05:06 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
The esc isn't going to give you more speed....the 35t will run a bit faster then a 55t though. Running a lipo pack isnt determined by what motor you run only the number of cells is.....your esc has to be compatible....most of the newer ones are! Last edited by jeepster73; 05-26-2013 at 05:14 PM. |
05-26-2013, 05:14 PM | #3 |
| Re: More wheelspeed for my crawler king
Im looking for torque im not really looking for a whole lot of speed, I have a 55t and can barely turn the tires when in a lil bind. Im looking to make the truck a trail/mud truck.
05-26-2013, 05:15 PM | #4 |
A 55t usually has plenty of Torque....what batteries are you runing?
05-26-2013, 05:17 PM | #5 |
venom 5000 mah nimh
05-26-2013, 05:21 PM | #6 |
So you are currently running that fireball thingy?
05-26-2013, 05:22 PM | #7 |
yea its a fireball 55t brushed motor.
05-26-2013, 05:22 PM | #8 |
The HH 35T is a whole diffrent breed of animal then the one you are currently running.
05-26-2013, 05:24 PM | #9 |
My assumption is that its that motor....throw in a HH and you will see what I mean.
05-26-2013, 05:26 PM | #10 |
seriously? U think the motor will give me alot more wheelspeed not really top speed. But im lookin for torque. i also plan to upgrade to lip when funds are available
05-26-2013, 05:36 PM | #11 |
That HH Torquemaster will give you plenty of both....if you want more grunt, then get a 55 or 65t
05-26-2013, 05:37 PM | #12 | |
| Re: More wheelspeed for my crawler king Quote:
ESC input voltage ESC (can it handle more input voltage) Motor (# of turns) Batteries (voltage & "punch") Gearing With a lower turn motor (35T vs. 55T), you can get more speed, torque can be added (speed lost) by changing gearing. Go to a larger spur or smaller pinion. Voltage, more volts + more power/speed. If you add volts, you change gearing, smaller pinion or larger spur (same as a lower turn motor). | |
05-26-2013, 05:39 PM | #13 |
I have personally have never ran a higher turn motor then a 35t.....a its always been plenty powerful for me.
05-26-2013, 05:42 PM | #14 | |
05-26-2013, 05:46 PM | #15 |
thinking about jus buying another truck and putting a gear reduction on this one lol
05-26-2013, 05:52 PM | #16 |
| Re: More wheelspeed for my crawler king Currently, he sounds like he is overgeared, thus smaller pinion or larger spur would likely help torque, but drop speed. Going to a 35T really NEEDS to be regeared the same way, mostly due to the faster motor. Any regearing I've suggested would help the current 55T as well as a 35T....I NEVER said to speed up the gearing (larger pinion or smaller spur). |
05-26-2013, 05:54 PM | #17 |
it may run about the most is 4mph if that
05-26-2013, 06:42 PM | #18 | |
05-26-2013, 06:46 PM | #19 |
Im saying that a HH 35t has more torque than his 55t fireball.. I wasnt even going to go into the subject gearing with the guy yet....i wasnt sure if he was familiar with motor basics yet....he has under 10 posts so I wanted to ease him into it. |
More wheelspeed for my crawler king - Similar Threads | ||||
Wheelspeed Q | Voteban | Electronics | 5 | 04-27-2010 03:20 PM |
Disadvantages and advantages of changing my wheelie king into a crawler king? | dudeka | HPI Wheely King | 18 | 01-09-2010 04:38 AM |
