05-27-2013, 10:54 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
| 17.5 gen2 redline with mmp issue
So yesterday I smoked a vxl, the insides came apart and decided to put my 17.5 redline in. Now if I'm really crawling slow for like 10 seconds and go to give it throttle it will not go any faster. Just stays the same speed. I can wiggle the steering left to right it will stop for a split second and accelerate and work fine. I looked at the green light on the esc and when it won't accelerate it goes to a steady green like its getting a full throttle signal. I wonder if the when I smoked the the motor it took the esc with it. I'm using a mmp and it worked flawlessly until I smoked the motor. Although I've never had a brushless sensored motor hooked to it before.
05-27-2013, 11:11 AM | #2 |
Rock Crawler Join Date: Dec 2009 Location: Redding
What happens at full throttle from a standstill?
05-27-2013, 11:33 AM | #3 |
| Re: 17.5 gen2 redline with mmp issue
Works fine going to full throttle from a stand still. Even part throttle. It only does when I creep for a few seconds and then try to throttle up.
05-27-2013, 04:23 PM | #4 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
esc is fine.. its something else.. is your motor good? sensor plugged in? did you change it to sensored brushless mode? is the sensor wire good? sounds like loading up and not going, some kind of protection mode. |
05-27-2013, 10:26 PM | #5 |
I tried sensored only, smart sense setting, I can't say for sure the sensor cable is good ill have to check it. Its almost like it gets stuck in one throttle position and won't go up no matter what I do with the trigger as long as I don't go to neutral. When it goes to neutral it stops moving like its supposed to, then when I give throttle it works like its supposed to as long as I don't crawl real slow for a few seconds. If I crawl a hair faster it works fine. Also if I turn the steering wheel left to right real fast when its acting up things work as they should.
05-28-2013, 02:33 AM | #6 |
I had exactly your problems with firmware 1.38 in the MMP. Going slow the green and yellow LEDs began flashing after about a second, and then you can't accelerate until you've stopped. Rolled back the firmware to 1.28 (by then the latest "release" version) and the problems went away, and now I'm running 1.39 with no issues. |
05-28-2013, 10:03 PM | #7 |
Just a little update. So I disconnected the servo from the reciever to see if the issue went away and it didn't. So I backed the firmware up to 1. 29 and the problem went away. So I updated it to the latest 1.45 firmware and everything is all good. Plugged the servo in and still all good. Ill run it a while and see what happens. I will be putting a bec in though. Thanks for all the help guys.
06-02-2013, 10:19 PM | #8 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Just asking why didn't you just but a tekin RS with this motor? If anyone knows me I run only tekin but in some conditions I run castle but I have an axial wraith with a gen2 10.5 turn redline sensored motor / gen1 ESC with a 3s high 50c 5000 mah lipo with a external cooling fan over the ESC and I tell you what that things halls a##. And it crawls good believe it or not it does. I can still go low throttle and climb a 90 degree wall till it flips over on its roof but my point is that in your case it may have to do with settings or updates as you sed. Hope that helped but I was just joking about tekin vs. castle because there both great brands, and they race almost the same. Lol.
06-02-2013, 10:26 PM | #9 |
Pebble Pounder Join Date: Jul 2010 Location: California
I would definitely wire an external BEC most ESC`s come with weak ones that just don`t cut it.
06-03-2013, 08:04 AM | #10 |
| Re: 17.5 gen2 redline with mmp issue |
06-10-2013, 06:25 PM | #11 |
Another update and another issue. I would have gone with the tekin rs but I had a mmp already. So I got to finally get out and do some trails this weekend and found another problem. The motor would cut out at full or close to full throttle. So I wired in a bec thinking I was having a brown out issue with the reciever because of the weak mmp internal bec. But it still continues to do it. Three different batteries all with the same result. This is on 2s batteries. Any thoughts.
06-11-2013, 12:06 AM | #12 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Set your throttle trim to 120%.
17.5 gen2 redline with mmp issue - Similar Threads | ||||
tekin redline gen2 2 pole or 4 pole | gofaster427 | Electronics | 2 | 02-24-2013 05:22 PM |
Tekin redline gen2 brushless motor | Camasrider | Electronics | 0 | 11-10-2012 10:54 AM |
