06-02-2013, 09:16 AM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: The Styrene Dungeon
| Help with Punk Dig
Recently rebuilt my comp Bully, and had to pull all of my electronics out, when I re installed my electronics, my Punk dig no longer works. It still switches and the lights change, but all I have is rear wheel drive. my front motor does not run. I did not disconnect any of the electronics from each other, just pulled them out as an unit & reinstalled them the same. The punk dig worked fine before removal. Any ideas what caused this? |
06-02-2013, 09:42 AM | #2 |
| Re: Help with Punk Dig
Does the front motor run at all? Did you hang a brush, or loosen a ESC/motor wire? |
06-02-2013, 10:08 AM | #3 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Help with Punk Dig |
06-02-2013, 07:49 PM | #4 |
The front motor does not run at all. Doesn't even try. I checked all of the connections & they are OK. I will check the relays tomorrow & see if one is stuck. Thanks for the replies.
