Thread: axial ae-1 esc problems
Old 06-03-2013, 12:01 PM   #1
Default axial ae-1 esc problems
I have an axial ae-1 esc and I will plug it into the battery which is a 2s 2450mah lipo, and it wont come on unless you wiggle the wires and get it in the right spot it will finally chime and I can drive but once I hit a bump or hill it just shuts back off and you have to wiggle the wires. I figure it is a connection problem? but wanted opinions from someone else.
scoggdog13 is offline   Reply With Quote
Old 06-03-2013, 01:49 PM   #2
Sounds like a loose internal wiring issue. But I'm pretty certain the ae-1 is lipo compatible but you must run a low voltage cutoff.
Heres a link for you
http://www.axialracing.com/faq
Sent from the end of my fingertips
Grichardson152 is offline   Reply With Quote
Old 06-03-2013, 09:12 PM   #3
Default Re: axial ae-1 esc problems
i run alarms for lipo but when it shuts off u have to wiggle the wires at the battery to esc connection
Old 06-04-2013, 05:04 AM   #4
What connectors are you running? SOunds like Tamiya which will be an issue at some point, Deans are a better choice.
Charlie-III is offline   Reply With Quote
Old 06-04-2013, 09:23 AM   #5
I run tamiya i have some xt-60 connectors i may use
Old 06-04-2013, 12:06 PM   #6
Good point! Most LHS have the deans in stock.
Old 06-04-2013, 01:14 PM   #7
Originally Posted by scoggdog13 View Post
I run Tamiya I have some xt-60 connectors I may use
Originally Posted by Grichardson152 View Post
Good point! Most LHS have the Deans in stock.
Tamiya plugs are KNOWN to have issues, if not new, then down the road. The XT-60's are a decent replacement. This may be a large part of your issues.
Old 06-05-2013, 08:03 PM   #8
wrx-n-ktm's Avatar
Go Deans and don't look back!
wrx-n-ktm is offline   Reply With Quote
Old 07-30-2013, 11:12 AM   #9
fixed that issue now I don't have reverse and idk what is wrong cuz it is not programmable. I was running it on a 27t axial motor and a 2s lipo. and I got through part of the g6 and it got real hot then I lost reverse. what has happened
axial ae-1 esc problems - Similar Threads
Axial esc problems Bermbuster210 Electronics 12 01-01-2013 02:10 PM
Problems with Axial AE-2 esc nathan000 Axial Wraith 0 03-07-2012 04:40 PM
My Esc problems.. I think GnarKill Electronics 0 07-08-2011 09:27 AM
Axial AE-1 ESC Problems FireWire79 Axial AX-10 Scorpion 6 09-13-2010 07:50 PM
HELP ME axial esc problems!! Streamcrawler Electronics 3 05-03-2010 06:14 PM
