06-05-2013, 02:00 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: sweden
| outrunner to replace 45cc gaS engine ?
hI ! I know this is not about crawler Electronics But mabe some one can help me any way ? i'd like to build an brushless weedwacker powered by a outrunner that puts out min 2000w and runs on 12s lipo. i know that hobbyking sells lot's of big outrunner do they have one that will fit my needs ? It chould be equal or mor powerfull compared to a gas 45ccengine. i'd like 25-40min of worktime on one charge ! Will 12s 5000mah be enough ? |
06-05-2013, 08:24 AM | #2 | ||
| Re: outrunner to replace 45cc gaS engine ? Quote:
2kW continous or peak? Quote:
There are quite a few motors that should fit your needs, even if most of them can't handle 12S directly. Just limit the max output voltage from the ESC. | ||
06-05-2013, 09:01 AM | #3 |
I wanna be Dave Join Date: Aug 2007 Location: *
| Re: outrunner to replace 45cc gaS engine ? |
06-05-2013, 09:52 AM | #4 | ||
Pebble Pounder Join Date: Dec 2010 Location: Fresno
I know my terminology is way off here. Please forgive. Quote: | ||
06-05-2013, 10:23 PM | #5 |
Those toro trimmers are gutless brushed direct drive. I have one, can't cut in before mowing. Gotta mow and then finish the edge. A 63mm outrunner is a good start, something at least 50mm long with a nice low kv 250 or less. You will need to make an adapter for the line spool. |
06-07-2013, 03:32 AM | #6 | |
1. The difference in feed between brushed and the type of brushless motors we use is that the brushed motors have two leads in where one is "positive" and the other "negative" whereas the BL motors have three leads the function of which change with the position of the rotor. So a brushed motor (while rotating in one direction) has the current fed in only one direction through the input leads. A BL motor has the ESC chop and alter the current fed to the three leads as the rotor turns. 2. "Voltage" is in all modern designs is regulated by pulse width modulation (PWM), which means that a high steady voltage is chopped and then distributed as a square wave where the peak voltage is (almost) the input voltage and the average is the desired output voltage. This output signal is often smoothed a bit using a capacitor or two. So running a BL motor designed for up to 10S on 12S is no sweat if: - The ESC can handle a 12S input, and - the max throttle is set to 83% (10/12) or less. (The limiting factor isn't the impulse peak voltage, but the average power generated over time.) | |
outrunner to replace 45cc gaS engine ? - Similar Threads | ||||
Mad Force with gas engine | Ludvig08 | Kyosho Crawlers | 3 | 05-06-2011 01:03 PM |
Looking to replace my HR chassi, but which one? | LEWETHETIGER73 | General Crawlers | 0 | 11-24-2009 06:03 AM |
Upgrade or replace | Greatscott | Axial AX-10 Scorpion | 7 | 11-15-2009 08:29 PM |
45cc gasser for $175 | JasonInAugusta | Chit Chat | 32 | 02-17-2008 09:42 PM |
