06-07-2013, 02:29 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
| My 1/6th scale servo problem solved HS-900SGS Operating Speed (11.1V):0.20 sec/60° at no load Operating Speed (14.: 0.15 sec/60° at no load Stall Torque (11.1V): 902 oz/in. (65 kg.cm) Stall Torque (14.8V): 1208 oz/in. (87 kg.cm) servo city link VV HS-900SGS Servo I already assigned enough room to fit a 1/4 scale servo and was possible going to use one if my Ti geared servos to steer my 1/6 Rock Racer but WOW this thing is awesome ok its really expensive also but this rig is getting pretty wild !! my plan is to use a 775 and an old EVX esc for now and eventually use a set up like a Novak Diablo so I'l have the voltage available ( already picked up lipo's for the brushless set up and have a ton of good standard batteries I might have to get 2 of them, the other for my 72" catamaran ( yea 1/6th also ) |
06-07-2013, 06:03 PM | #2 | ||
| Re: My 1/6th scale servo problem solved Quote:
Da heck?.... droppin' that on us when I'm all out of jawdrop smileys........ | ||
06-07-2013, 08:21 PM | #3 |
it would be like a slingshot... lol !! sorry 'bout your jaw, yea I got a 72" offshore catamaran made by Capricorn Boats (not even sure if they still exist) just like this one V 72inch capricorn rc boat - YouTube Its going thru a slow re-paint & re-build/ electric conversion. Going to convert to single rudder also . want to go with the equivilant of 2 Castle 2028's but water-cooled and run 36volts, that will give me 20 hp and enough rpm to get over 100mph...... I hope just for sheer strength I scratch built my struts, rudders and brackets all out of 316 stainless steel and steer it with aircraft rod ends |
My 1/6th scale servo problem solved - Similar Threads | ||||
wraith glitching. (PROBLEM SOLVED!!!!) | OhioSuperSport | Axial Wraith | 8 | 03-11-2012 06:52 AM |
fxr problem?---*SOLVED*--- | Mr. crawl | Electronics | 13 | 07-26-2011 10:15 AM |
Solved my Torque Twist Problem | tbizzle | Axial AX-10 Scorpion | 13 | 03-22-2010 07:35 PM |
driveshaft problem solved | crawler-kid | Venom Creeper | 4 | 12-15-2009 04:18 PM |
Heat problem solved...period | grouser | Team Losi Comp Crawler | 2 | 06-22-2009 10:20 PM |
