06-08-2013, 10:18 PM | #1 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| removing red wire on 3s
Got a HH BRXL, while using 3s or larger do i need to remove red wire from esc to rec??? 3s is most i have ever used with other esc & always remove red...Making sure!!!
06-08-2013, 10:20 PM | #2 |
| Re: removing red wire on 3s
Are you using an external bec?
06-08-2013, 10:22 PM | #3 |
Oh yes!
06-08-2013, 10:52 PM | #4 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Any time you use external bec directly to your rx you need to remove red wire from esc. Does not matter what size battery you use. Supplying your esc two ways may damage your rx. Also there are two different ways to use a bec. You can also keep red wire in to power esc and use power and ground from bec ran directly to servo and supply a wire from rx to servo for the signal. This will result you to send more than 6 volts to the servo and not risk blowing the rx by sending too much power to it. |
removing red wire on 3s - Similar Threads | ||||
Red wire missing? | demonoid369 | Electronics | 5 | 05-10-2011 07:12 AM |
How do you remove red wire off esc? | boisetrucker | Electronics | 3 | 05-18-2009 09:14 PM |
cut the red wire on the mamba max | madmax412 | Electronics | 3 | 03-21-2009 08:23 PM |
How do I pull out the red wire on my FXR? | BigB_117 | Electronics | 7 | 03-16-2009 07:36 AM |
how do I wire red LEDs so it will light up during braking? | ussprinceton2004 | Newbie General | 0 | 03-07-2008 05:33 PM |
