06-13-2013, 11:33 PM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Winch electronics question
How do most winches get their power? From a separate battery pack or from the main battery? Also how do you control it. Manually or by 3rd channel..? I have a 3 channel dx3e and I'm using the 3rd channel to operate a shift servo. Can i control the winch off that 3rd channel by using some sort of toggle or manual switch so I can use the radio to pay out or reel in the winch cable. So basically hit the switch which disables the shift servo and sends a signal to the winch instead giving me remote control. |
06-14-2013, 07:02 AM | #2 |
| Re: Winch electronics question
i run mine with a seperate battery pack , others use the 3rd channel. check out "HEYOK" he makes some nice winch contrllers
06-14-2013, 10:03 AM | #3 |
The toggle switch idea works well. When you need to winch, you will have to touch your rig anyway, so just throw the switch from the shifter position to the winch position. When you are finished winching, just flip the switch back. I can make you this switch with the servo connectors on it so all you have to do is plug it in - no soldering needed. Send me a PM if you are interested. |
06-14-2013, 10:34 AM | #4 |
What's working for me is a servo winch controlled by a mini 10amp brushed esc powered by a dedicated ccbec set to 8v from the main 3s pack. A momentary 3pos switch makes the driveability awesome during winching.
06-22-2013, 09:04 AM | #5 |
Newbie Join Date: Aug 2011 Location: Surrey
Or one can purchase a remote controlled winch at RC4WD. It's a cheaters way of adding a forth channel |
Winch electronics question - Similar Threads | ||||
Got an electronics question for ya(non-RC)... | BigJay | Chit Chat | 17 | 05-22-2007 07:25 PM |
electronics question | truegaintfree | General Crawlers | 4 | 09-22-2005 07:53 PM |
