06-14-2013, 11:02 PM | #1 |
Going Fast Join Date: May 2011 Location: Hazzard County
| Need help for Axialfest!!!
My hitec 225 mini servo I use for my 2 speed tranny keeps frying. Here's what I've got. Futaba 4pl with 4 channel receiver Hitec 225 mini servo (2) Hitec 7980 Monster Torque Servos Mamba Max Pro esc Castle BEC Pro (the one with 2 receiver plugs) So I left one of the bec plugs loose because there are 5 channels on the reciever including the Bind channel. I desperately need some answers A.S.A.P!!! BTW This will be to get Game Changer to Axialfest. |
06-14-2013, 11:08 PM | #2 |
| Re: Need help for Axialfest!!!
Sounds like the EPA's are not set correctly and you're overdrawing the servo. This causes it to get hot & fry. Set your EPA just short of where the trans htis a mechanical limit. |
06-14-2013, 11:32 PM | #3 |
| Re: Need help for Axialfest!!! |
06-14-2013, 11:35 PM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Voltage? If you are running 2x 7980 each one should be tagged into its own BEC plug. Then use the MMP to power the RX and 225.
06-15-2013, 12:10 AM | #5 | |
| Re: Need help for Axialfest!!! Quote:
Sounds like a simple enough fix and is probably my problem. But could you explain exactly what you mean by tagging each servo into its own BEC plug? Thanks! | |
06-15-2013, 02:39 AM | #6 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
06-15-2013, 08:03 AM | #7 |
Pebble Pounder Join Date: Jun 2013 Location: Northridge,Ca
I might be attending! Sent from my iPhone 5S 1/2 |
06-15-2013, 09:44 AM | #8 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Post #122 top pic....... Run steering servos like that, don't pull red wire from esc. Definitive wiring diagrams for BECs Rx Servos Motors etc. Run smaller servo directly to rx. Personally I don't run the pro I use just the 10 amp bec and run one to each steering / winch servo. Also never had good results for running a 225 on my dig for comps. Just didn't have enough balls so I moved up to a 5645 for more power but obviously took up more space. Last edited by JokersWild; 06-15-2013 at 09:53 AM. |
06-18-2013, 06:41 PM | #9 |
Just got it all hooked up with only the yellow wire from the 7980's going to the reciever and the power wires directly soldered to the bec pro. BUT my rear steer servo glitches often and doesnt follow directions! Also I noticed my front 7980 got VERY hot, too hot to touch! So whats the deal with that? |
06-18-2013, 10:04 PM | #10 | |
Well more than likely you stalled the servos. What's the voltage you are running and have you checked actual voltage from bec wire? Also your steering geometry may be poor creating the servo to work really hard to move the wheels. Not sure about the rear glitch. Does rx flicker when it glitches ? And can't be any help on the pro due to I don't use them. I only use the single 10 amp per servo. You need to turn on the overload protection and set @ 10% also if you have overheating issues. | |
06-18-2013, 10:49 PM | #11 | |
Need help for Axialfest!!! - Similar Threads | ||||
Roxanne...... axialfest build | FRENCHBLUE72 | Multi Axle Rigs | 25 | 03-11-2014 02:57 AM |
Axialfest 2013? | BentMetaL | General Scale Talk | 2 | 05-19-2013 02:17 PM |
Axialfest: Does not look like a bust to me | The Violator | Chit Chat | 18 | 06-27-2012 11:41 PM |
