06-16-2013, 03:08 PM | #1 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| need guru help
setting up mmp and tekin pro4 3300 kv with 3s 5000mha pack 11/56 32p gears is there any settings i need to add so i dont fry any thing it will be in my nine pound scx with ttc baja claw tires
06-17-2013, 01:45 PM | #2 |
| Re: need guru help
Sounds about right. Do you have a BEC and beefy servo? Make sure to use a servo bypass harness and not run the straight voltage through the RX (if you're using high voltage).
06-17-2013, 01:50 PM | #3 |
| Re: need guru help
IMO, 11/56 is geard a little high for that heavy of a truck... not real high, but just a little. Keep an eye on temps and maybe a 6:1 ratio standing by. I set my drag brake to 40%, I've found that it's a good compromise. |
06-17-2013, 07:11 PM | #4 |
| Re: need guru help
ok i will have to order more pinnions will a 60 tooth spur fit with mip shafts and my batt is a 25c will it be ok
06-18-2013, 10:57 PM | #5 |
Going Fast Join Date: May 2011 Location: Hazzard County
| Re: need guru help
You definitely need more C's. I tried the some setup with a 20c batt and it ran poorly. Now I run 65 and 70c batts The pro4 is a beast, it needs C's
06-19-2013, 03:54 PM | #6 |
| Re: need guru help
even at 5000mha
need guru help - Similar Threads | ||||
Chaotic guru help please | scorpion_ax | Axial XR10 | 42 | 11-27-2012 04:09 PM |
I Need an iPhone Guru | Knarly Nerd | Chit Chat | 22 | 04-23-2012 12:23 PM |
Looking for a radio mod guru | BlueMonster | Electronics | 8 | 02-28-2008 11:31 PM |
Internet guru help me!!! | slobin3d | Chit Chat | 6 | 03-16-2007 08:10 PM |
MS Paint Guru | dezfan | Chit Chat | 8 | 12-04-2006 12:16 PM |
