06-19-2013, 12:56 PM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| ~ We need better high-current connectors ~
First came the Tamiya connector.... all fine and dandy seeing as most NiMh stickpacks didnt pull enough current for the most part. And if you went to the high-end batteries there were Deans connectors that was the solution. as time went on we started seeing other connectors other then the Tamiya or Deans such as EC3, TRX, Bullets, etc... however, im finding that with all thats on the market these days just doesnt cut it when you start playing with serious power. Ive destroyed more Deans connectors then i can count, wires coming loose from EC3's, etc... it would be great if someone could do some R&D on a new connector that could take the amper draws on these LiPo's aswel as a clip to keep them tight such as that from a Tamiya connector which i think would do the trick. With that being said, something that we can get a real good solder joint to work with unlike EC3 or TRX high-current connectors. Any thoughts?? |
06-19-2013, 02:44 PM | #2 |
I wanna be Dave Join Date: Aug 2007 Location: *
| Re: ~ We need better high-current connectors ~
Losi EC3 and EC5 connectors are meant to be soldered... If you need more current capacity than a EC5 can support you need to consider this: |
06-19-2013, 02:52 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Just use Castle Creations 4mm bullet connectors for everything. That's what I'm doing to my Losi Ten-SCTE racer.
06-19-2013, 02:54 PM | #4 | |
| Re: ~ We need better high-current connectors ~ Quote:
i aware that EC3/5's need solder.... but EC3 just isnt enough and the wires break loose on my C1 Apache and EC5 are just to big in I.D to fit a wire coming off a MMP, which means filling far too much solder into the joint. i dunno....maybe its just me? i just aint having luck with the connectors out on the market. | |
06-19-2013, 03:23 PM | #5 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
I run EC3 on my stuff, not one broken solder joint, or any heat at the plug after a run. I run up to 4S battery on crawler and a SC10 4x4. Never once have I had an issue.
06-19-2013, 03:31 PM | #6 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
I just switched to these from deans. http://www.hobbyking.com/hobbyking/s...s_GENUINE.html |
06-19-2013, 03:51 PM | #7 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Re: ~ We need better high-current connectors ~ Anderson Power Poles were/are an old RC standby. They can handle some silly voltage/current. The top of the line can do 600v at 350a! That might be a bit excessive, but I've heard these things are pretty good.
06-19-2013, 03:57 PM | #8 |
Whats wrong with the old school Anderson power pole plugs? Half my fleet still uses them. Easy to solder, cheap, and I've never melted one. I even used them on a 1:1 truck with a Ford Taurus fan, and those things draw enough amps to melt cheap relays. The other half of the fleet is using Traxxas plugs, and I hate them. While easy to solder to, they can by finicky about sliding into the plastic. I also have a few that like to come apart mid-run, like they don't hold tight like they did when new. I'm paranoid about electronics (mainly batteries and ESC)s that use female bullet connectors right on the board, or inside the case. Admittedly, I'm hard on equipment, but that seems like a broken connection waiting to happen. |
06-19-2013, 03:59 PM | #9 |
If you need more current flow than a 4mm bullet can handle you really should be looking at swapping out the wires for something bigger. In the fast electric boat world ESC's like my 180 amp SeaKing come with 10 ga wire to handle the current. My boat has 5.5 mm connectors on it I believe but 8mm would work as well. I like shopping from these guys: Building Supplies, Wire & Connectors & Shrink Wrap | Rc Boats by OffshoreElectrics |
06-19-2013, 06:26 PM | #10 | ||
For all our crawler rigs, we use the APP's (except for the 1.9 comp rigs...we use mini Deans for those), never had an issue with 3S high "C" packs in a MOA. Frankly, with some of the thin ga wires the "lightweight guys" are running, Deans should be fine handling the power. | ||
06-19-2013, 07:06 PM | #11 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
While on the subject I'll point out there is a difference between knockoff deans and real deans. If they don't come in a package with the deans logo, they aren't the same.
06-19-2013, 08:18 PM | #12 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: ~ We need better high-current connectors ~ X2! I've soldered both recently, and the Deans DIDN'T melt! Granted, my soldering skills are highly corroded but, damnit those cheap Chinese pieces melted almost instantly!
06-19-2013, 08:19 PM | #13 | |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
These are quite good. There is a HD version too XT90, rated at 90Amp constant. | |
06-19-2013, 08:31 PM | #14 | |
For the OP, increase your wire gauge and upgrade to 5.5mm bullets. | |
06-19-2013, 08:50 PM | #15 |
| If you are melting them while you solder on the wire then you are doing something seriously wrong. Tin the connector, tin the wire, and then lay the wire on the connector and push it down with your iron. The iron melts the solder in the wire which in turn melts the solder on the connector and you are done in seconds. Just make sure that you see the solder on the connector go wet so that you don't risk a cold joint.
~ We need better high-current connectors ~ - Similar Threads | ||||
Turnigy high current wires | brianw | Electronics | 16 | 02-25-2012 04:46 PM |
Current JK | Deezul | 1.9 Scale Rigs | 6 | 07-26-2010 08:31 PM |
Traxxas High Power connectors. | Gozer | Electronics | 1 | 10-30-2008 02:49 PM |
