Thread: Timbuk2 wraith question.
Old 06-21-2013, 11:30 AM   #1
Default Timbuk2 wraith question.
I finally got my wraith together and I used the Novak timbuk2 "wraith edition" combo. It's working great except for if I'm at full lock on the steering and attempt to give it throttle its glitches out and does odd things. The combo came with a capacitor that has a plug to go into the RX, would this solve my issue?
Cmarcan167 is offline   Reply With Quote
Old 06-21-2013, 11:36 AM   #2
It would help, but a BEC would be better. Also, see if turning down your steering end points helps. At full lock, you're running the servo at full power with nowhere to go.
monkeyracing is offline   Reply With Quote
Old 06-21-2013, 11:37 AM   #3
It should help the issue, you can also get a bec, that will also fix your problem.
-sent from my smarter than me phone
mjc597 is offline   Reply With Quote
Old 06-21-2013, 08:22 PM   #4
Default Re: Timbuk2 wraith question.
Thanks guys. It doesn't do it much so ill try the cap before the bec.
Timbuk2 wraith question. - Similar Threads
Another Timbuk2 Question... Freakshow185 Electronics 6 05-06-2013 10:21 PM
Help..Novak Timbuk2 Wraith edition bignose13 Axial Wraith 4 01-06-2013 12:29 PM
Novak Timbuk2 Wraith Edition GravelDuster Axial Wraith 8 09-01-2012 08:41 AM
Timbuk2 Wraith Edition Problem? Team Jeff Axial Wraith 7 01-18-2012 09:28 AM
