06-22-2013, 10:45 PM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: lost
| Please help servo twitching! |
06-23-2013, 12:07 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Please help servo twitching!
Send back to hitec...... Either bad bearing (blown out), pin had wollowed on case top, or pot is bad. Servo can not find exact center.
06-23-2013, 12:37 AM | #3 |
Well I wish I could send it back but I got this servo on a rig that I traded for so now I'm out a rig till I get this fixed or get a new one but no cash...
06-23-2013, 12:49 AM | #4 |
Pebble Pounder Join Date: May 2013 Location: willow
I have a hitec 5955tg titanium gear its used but works fine wouldnt take much to get it off my hands pm if interested
06-23-2013, 02:55 AM | #5 |
Quarry Creeper Join Date: May 2009 Location: India
There can be a possibility that the BEC for some reason put out voltage that was over the internal IC`s tolerance level. That might have killed the IC and hence its not able to process. If you are able to move the servo to any side of its limit then it is a pot problem. If you are not at all able to move the servo what so ever you do, then the IC or some internal electronics has gone bad. |
06-23-2013, 01:46 PM | #6 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
To many Redbulls....
06-23-2013, 03:44 PM | #7 |
Without watching the video, I was thinking, "Digital servo neutral twitch", after seeing the video, yes, the servo has issues. Send it back to HiTec, while it may cost a few dollars, they have treated many on here rather well. |
06-23-2013, 06:32 PM | #8 |
With the servo off, check to see how much rotational slop the output shaft and servo horn has, and also how much in/out play it has. The in/out play would be a sign of worn output shaft bearings, the rotational slop would be worn gears, or the bushings that hold the pins in place are egged out. Both of those cases, you may as well send it in to Hitec. If the output shaft is tight, then you might have a dirty potentiometer inside the servo. If your handy you can dissasemble the servo and flush out the potentiometer with some plastic-safe electronics cleaner. I've had a couple of 7954's that had dirty potentiometers, caused by water intrusion during submerged usage. Flushing the potentiometers out with electronics cleaner saved them both. I had the same thing happen to a Savox 1268, and it too was saved by flushing out the potentiometer. |
06-23-2013, 06:46 PM | #9 |
Well there is no slop in the servo that I can feel... And to flush the POT hue would I do so? I have torn apart servos before to either make them into servo winches or just cause the gears stripped and wanted to know what gear stripped
06-23-2013, 09:58 PM | #10 |
Newbie Join Date: Jun 2012 Location: Naugatuck, CT
My brand new ones makes a strange noise... Hi-Tec HS-7955TG weird noise - YouTube |
06-23-2013, 11:49 PM | #11 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
The noise at center is normal for a coreless digital servo, the noise from when you are all the way left or right is you are hitting a mechanical stop in your steering, turn down your end points a little. Those were the only noises I heard after I turned my volume up.
06-24-2013, 01:02 AM | #12 | |
| Re: Please help servo twitching! Quote:
06-24-2013, 01:46 AM | #13 |
| Re: Please help servo twitching! |
06-24-2013, 05:35 AM | #14 |
Okay, this is my first coreless servo... just upgraded from a HS-5645MG so I wasn't sure what to expect, lol.
Please help servo twitching! - Similar Threads | ||||
servo twitching | jkurb00 | Electronics | 4 | 03-03-2012 06:31 PM |
Servo twitching | Merkaba | Losi Micro-Rock Crawler | 5 | 03-10-2010 10:09 AM |
twitching servo | tt454 | Electronics | 2 | 01-12-2010 09:34 AM |
Servo twitching | ccannon222 | Axial AX-10 Scorpion | 9 | 01-04-2009 07:29 PM |
Front servo twitching | muddeprived | Tamiya Clod Buster | 6 | 08-01-2007 02:09 PM |
