06-23-2013, 10:26 AM | #1 |
Newbie Join Date: Jul 2008 Location: Eugene
| Venom pro charger vs. thunder ac6 charger
I am considering buying either a venom pro charger or a thunder ac6 charger. Which is better? They seem similar and do the same thing. After researching them, I can't decide which is better. What's the main differences between the two(besides price.) I've got a couple 3s lipos I will be charging. Venom pro charger : LiPO Battery Charger - Pro Charger with Power Supply | Venom RC Thunder ac6 charger : Thunder AC6 Smart LiPo Balance Charger/Discharger w/ AC Adapter for 1-6 Lipo/ 1-15 Nimh + USB to PC Software |
06-23-2013, 10:44 AM | #2 |
| Re: Venom pro charger vs. thunder ac6 charger
We own 2 of the green Venom ProChargers (almost 2 years now) and a red ProCharger+ (over a year, bought used). They work well, only issues I have had were: First couple of balance ports (separate adapter) had issues, replaced free. Sometimes noisy cooling fan (sorta common, sound goes away but I will likely replace them at some point). They had most of the adapters we needed (except for Anderson PowerPoles...chopped up a different adapter & changed the connector), work well of a car battery/DC supply or house current. They are likely a little more costly than most any Thunder charger, but I have been happy & would recommend them. PS, the balance ports are the "Align" or "JST" style just so you know. Not all packs will fit the balance port, goes for any charger. |
06-25-2013, 06:20 AM | #3 |
Rock Stacker Join Date: Feb 2011 Location: Mount Gambier
I wouldn't get either I have had problems to the software on my Venom charger. I would recommend a Icharger because they are a higher amperage charger to charge bigger packs.
06-25-2013, 09:23 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
Red Venom pro is awesome! 2s 5000mah and nimh 220mah.
06-25-2013, 09:43 AM | #5 |
Rock Crawler Join Date: May 2012 Location: Columbus
iv got red venom pro and took some time to figure it out but I love it now
06-29-2013, 09:11 PM | #6 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
| Re: Venom pro charger vs. thunder ac6 charger Quote:
AC6 - No fan, so it gets a little hot during charging - nothing alarming. The storage mode is much better and faster. No power supply, just power cord to wall, nice. About a year old. Paid ~$40. Venom - This is my field charger, it has the battery leads already attached so I can't forget them (the ones that you use to connect to your car battery for charging in the field). I think the balancing block is better, but have not have had any problems with either. About 4 years old, still solid. Paid ~$100. I think that this bad boy is a must either way. I got one for both chargers. Has connectors for everything I need to charge. Multi-Connector Adapter:4.0mm to Futaba TX,JR TX,JR RX,JST,TRX Hope it helps. Last edited by dentonmac; 06-29-2013 at 09:13 PM. | |
06-30-2013, 01:16 PM | #7 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
i have the green venom pro charger and i love mine ( i agree that the cooling fan can be a bit noisey at times ) and i would buy it again
06-30-2013, 04:20 PM | #8 |
I've no personaly experience with the venom charger. I do have the Thunder AC6. Been using it over a year. Only real complaint is that the balancing plug has a very short lead, and so do some of my packs. Works flawlessly, comes with 120VAC and a 12VDC plug, charges all types of common R/C batteries at up to 5 amps. Comes with adapters for receiver packs, and aligator clips, but no Anderson or Traxxas plugs. |
Venom pro charger vs. thunder ac6 charger - Similar Threads | ||||
Thunder AC6 Charger (help) | Jeepster77 | Electronics | 17 | 03-02-2013 09:06 PM |
thunder ac6 charger help | throttlejock27 | Electronics | 7 | 06-10-2012 07:24 PM |
Thunder AC6 charger | hende | Electronics | 13 | 09-23-2010 05:59 PM |
Thunder AC6 charger | lumpy85 | Electronics | 5 | 08-18-2009 08:26 PM |
