06-25-2013, 01:03 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: vienna
| motor turn to kv conversion chart
I found this info from the following site, that maybe helpful to some Brushless Motors it help me out alot |
06-25-2013, 10:36 PM | #2 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Looks like it will work for general 1/10 motors. I dont think itll work for 1/8 motors since my 2400 watt 2560KV motor is not close to anything on there. Sent from my Transformer using Tapatalk 2 |
06-25-2013, 10:55 PM | #3 |
| Re: motor turn to kv conversion chart
Besides the use of "censored" instead of sensored, and his broad assumption that all 540 motors have the same KV for a wind, its a good effort. At least it gives people a ballpark to start with, but don't read too deeply into it or expect motor speeds to follow the chart closely. Even the method of determining KV isn't standardized in the business, so one company may rate it at zero amps and high timing with an AC voltmeter and another is rated under no load and low timing with a peak to peak measurement. Its a very loose system, quite maddening for a person trying to collect an accurate data set. |
06-27-2013, 04:35 AM | #4 |
Newbie Join Date: Jun 2013 Location: Internet
Thanks for sharing motor turn to kv conversion chart informative guideline. Its really useful and acknowledging post. NTEP Scales Last edited by Edward Ronald; 06-28-2013 at 10:51 PM. |
motor turn to kv conversion chart - Similar Threads | ||||
motor turn to brushless rpm/v conversion? | STANG KILLA SS | Chit Chat | 5 | 02-09-2015 04:13 PM |
Higher Turn Motor Vs Lower Turn Motor ? | ReignMan | Newbie General | 10 | 11-15-2009 10:40 PM |
higher turn motor or lower turn motor......... | bob1961 | Newbie General | 6 | 03-18-2008 09:16 PM |
