06-28-2013, 10:39 PM | #1 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
| Castle link help!
How do I get the castle link to recognize the cc bec? I read the FAQ about what to find in my device manager to enable the driver but what the faq is asking for is not in the list.
06-28-2013, 10:58 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: USA
| Re: Castle link help! Make sure you aren't pluging it in backward, I have done that a few times with MMP and Sidewinder
06-28-2013, 11:08 PM | #3 |
Yup its plugged in right. Brown with the - negative pin. This is beyond frustrating.
06-28-2013, 11:10 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Dumb question, but did you download the Castle Link software?
06-28-2013, 11:13 PM | #5 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
plug in a battery after plugging the link. Beyond frustrating is right.
06-28-2013, 11:28 PM | #6 |
Did you run the software as administrator?
06-28-2013, 11:31 PM | #7 |
RCC Addict Join Date: Oct 2012 Location: Norcal
When I program mine I didn't plug in the battery? Even my HH BXRL. If i remember right. It has been awhile though. I could be wrong though. |
06-28-2013, 11:34 PM | #8 |
I wasn't given the option to run the program as an admin. I am running windows 8. Does that make a difference?
06-28-2013, 11:49 PM | #9 |
I don't know about windows 8, but after i downloaded it i had to run it that way
06-28-2013, 11:49 PM | #10 |
Not sure, Win 7 here, but you should be able to program a cc bec without even putting in your rig. Do you have the latest version of the software?
06-28-2013, 11:52 PM | #11 |
You trying to set it at 6.0v of higher?
06-28-2013, 11:56 PM | #12 |
I guess it does not matter if Win 8 is the issue.
06-28-2013, 11:59 PM | #13 |
Xp and Win 7 are the only two OP systems I'll ever run. Not that it shoukd make a diff.
06-29-2013, 12:00 AM | #14 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Plug a lipo in and see if that helps.
06-29-2013, 12:12 AM | #15 |
You can buy a CC bec and have it set at what you want from almost any hobby anywhere, it does not even have to be hooked up to your rig.
06-29-2013, 12:21 AM | #16 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
im using windows 8 and I just followed the pop up instructions, mine works great sorry I cant help you. I too did look for the admin setting but there wasn't one so I just clicked the tab it recommended and it works on both my bec's
06-29-2013, 12:23 AM | #17 |
I had the hobby shop program the bec. I installed it a month ago and the bec fried the throttle band on my receiver. I now have my receiver warrantied thru axial. I would like to run the bec BUT first make the settings right through the castle link. I cannot get the castle link to work on my laptop. |
06-29-2013, 01:16 AM | #18 |
Pebble Pounder Join Date: Oct 2012 Location: Plattsmouth
I had to plug mine in to several different ports on my lap top be fore it registered but I'm not sure why???
06-29-2013, 02:12 AM | #19 |
I tried every port. Just to clarify. I have downloaded the castle link software. I plug everything in and the USB connection status stays RED. (Green means connected) I follow the tips and suggestions under "connect device to castle link" and that's where I run into this driver problem. I don't believe I am the only one having these problems. I am ready to return these products at this point. |
06-29-2013, 03:20 AM | #20 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
If the BEC is soldered to the battery connector or ESC posts (basically if attached to ESC through the battery wires) then make sure the ESC is off. Otherwise it will not recognize it. I had this problem until I turned off the ESC
