Thread: HELP leds
Old 06-30-2013, 06:24 PM   #1
Default HELP leds
after doing my own lights they arnt as bright as I thought they would be and this is like the 3rd try could someone recommend some bright leds for my scx10 and not a pocket breaker
that also take a 9v battery
Ohioskills is offline   Reply With Quote
Old 06-30-2013, 06:53 PM   #2
Default Re: HELP leds
i dont know any that take a 9v, but i use the Axial simple led controller with 4 white lights and 2 red lights. Works great, plugs into the receiver. Then you don't need an extra battery. I also have one of the Vanquish light bars that wires directly to the 3s lipo battery. I have my lights attached to the body, and use a Dean's 4 pin connector to connect my two light systems when I put the body on. The simple axial led system is very cheap. The vanquish LED bar isn't cheap, but has amazing lighting ability.
uclabruins89 is offline   Reply With Quote
Old 06-30-2013, 08:11 PM   #3
The brightness of the LED is a combination of how bright the LED is designed to be and the amount of current going through the LED.
Here is link to the LEDs that I used in my Wraith. When put in a circuit with proper voltage and resistance they are bright.
5mm White LED | Through Hole LEDs | Component LEDs | Super Bright LEDs
I have been using the HeyOk lighting brake light controllers.
HeyOK's RC Electronics items (all in one place)
k7zpj is offline   Reply With Quote
HELP leds - Similar Threads
Leds? scx10 honcho Losi Micro-Rock Crawler 6 12-11-2011 08:22 PM
Leds justinhinger Electronics 4 04-08-2011 07:17 PM
little help with leds please!!! lordjasper1988 Losi Micro-Rock Crawler 5 03-09-2011 05:14 PM
LEDs TBex Electronics 3 06-13-2009 05:28 PM
LEDs cammok5 Chit Chat 12 10-16-2006 10:26 AM
