06-30-2013, 06:58 PM | #1 |
Newbie Join Date: Jun 2013 Location: Burlington
| Hi Tech 5645mg
Just got the Hi-tech 5645mg on friday for my wraith. Used it just for some fun while I was at my cottage and I hear grinding out of the servo. Great stripped brass gears. Anyone have this issue or recommend a servo that will not blow up with the aluminum steering linkage?
06-30-2013, 07:27 PM | #2 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Hitec 7950, last servo you'll buy
06-30-2013, 07:36 PM | #3 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
| Re: Hi Tech 5645mg
I've had good luck so far with the Hitec 7954.
06-30-2013, 09:04 PM | #4 |
Rock Crawler Join Date: May 2011 Location: at your moms
| Re: Hi Tech 5645mg
the 5645s that i have left i plan on rebuilding them 1 time a year anyway, $17 for the gear kit, the above 2 servos are very good servos
06-30-2013, 09:43 PM | #5 |
7950 due to the gears, 7954's snap
06-30-2013, 11:29 PM | #6 |
| Re: Hi Tech 5645mg
Decent but a little lower price, HiTec 7955. Good but more money, HiTec 7950. I've had a few 7954's but had issues with them, I no longer recommend them. |
06-30-2013, 11:30 PM | #7 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Hi Tech 5645mg Quote:
645 is analog...... 5645 is same servo different board..... Same gears and motor.... Just digital version. Digital does see a slight increase in power @ 158 oz vs 133. Still worthless on steering. The above servos not only handle 7.4 volt and the above handle only 6 volt...... on 7.4 see a height of power at 486 oz / in of tq. Just over 3 times the power..... Buy once and be done. A litte more than just good. | |
07-01-2013, 08:13 AM | #8 |
| Re: Hi Tech 5645mg
Thanks everyone. Looks like if I have to spend some cash I must. In less then 2 weeks I stripped the gears in the stock servo and the 5645mg. Its pretty much stock except for the aluminum steering linkage and using 2cell Lipo's. Clearly I need some that will stand up to something. Hopefully I can get my hobby store do return it or get me a rebuild kit and keep it for something else in the future. |
07-01-2013, 10:01 AM | #9 |
| Re: Hi Tech 5645mg
Buy new gears..... Ditch the board...... Heyok controller and a machined winch spool. Turn into a winch. About all they are good for...... Dig maybe but kinda on the large side!
07-01-2013, 10:07 AM | #10 | |
I just built a 645 servo winch and it will pull my wraith straight up no problem. Only thing I did different was to buy the Robot servo HSR1425CR for the control board. $17. Works like a charm. | |
Hi Tech 5645mg - Similar Threads | ||||
Hs-5645mg - :( | B94Cast | Electronics | 11 | 11-19-2012 02:16 AM |
hi-tech HS-5645mg | joshlg06 | Losi Mini-Rock Crawler | 5 | 05-26-2011 12:43 PM |
hitec hs-5645mg | m3kan1k | Electronics | 8 | 03-03-2009 02:01 AM |
warm 5645mg | heeper40 | Electronics | 1 | 04-27-2007 06:48 PM |
