07-01-2013, 09:05 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: opp
| battery help
I've found a takon 3650-4420 brushless motor and esc but am curious what the best battery would be.also I'm new don't bash me to hard plz
07-01-2013, 09:33 PM | #2 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
| Re: battery help
What are you going to use it for? How long do you want to be able to run between charges? What kind of charging equipment do you have?
07-02-2013, 01:54 AM | #3 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| Re: battery help
This question depends a lot on what you plan on doing with it, really. Is it a sensored brushless motor, or sensorless. Do you plan on crawling, trail-running or trying to get speed out of it? I have had good luck with the Turnigy batteries, if you can find good deal on them. But there are also a few other well-recommended brands like GensAce.
07-02-2013, 06:54 AM | #4 |
| Re: battery help
It's going into a 1/6 avalanche build.I'm using a wheely king as my donor.it will be a mud truck pretty much basher but may Do a crawl here or there.torque and wheel speed are my goal if that makes since.I'd like it to last as long as possible .as for charging system a stock wheels king charger.so I'll need input on a charger as well.thanks in advance
battery help - Similar Threads | ||||
UK Version please - LOSB0862 Battery Charger & Battery. | newth | Losi Micro-Rock Crawler | 7 | 05-26-2010 01:38 AM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
Finding bad battery cells in a battery pack. | ToTheMAXXcrawler | Electronics | 9 | 02-04-2010 10:14 AM |
