07-06-2013, 04:55 PM | #1 |
Rock Stacker Join Date: May 2013 Location: Goodyear
| novak rooster crawler w/p points
ok, so I'm thinking of just using dielectric grease to waterproof my esc, but i don't know where to grease. any input from the veterans here?
07-07-2013, 10:57 AM | #2 |
| Re: novak rooster crawler w/p points
I've waterproofed a few ESC's with dielectric grease, ranging from a Duratrax Streak, to a Mamba Max Pro, and the theory is always the same: Remove the circuit boards from the plastic case and make sure you have both sides of the entire circuit board coated with grease and no air bubbles. Some ESC's have two layers of boards and it can be a real PIA to get the grease all the way between the boards. It's kinda messy. I tend to use enough grease that it will ooze out of the holes when the case halves are reassembled. Remember, if it's full of grease, then water can't get in. If your ESC has a switch, do yourself a favor and just solder the wires together. Any switch will inevitably develop problems down the road once it's been dunked, and run in sand or mud. |
novak rooster crawler w/p points - Similar Threads | ||||
burnt out my novak rooster crawler today looking for some input on the novak eiger? | laxjj14 | Electronics | 5 | 05-16-2012 08:55 AM |
Tekin Rebel 2/novak Rooster Crawler/novak Super Rooster? | CHRIZAD | Electronics | 7 | 09-15-2008 07:22 PM |
novak rooster crawler | skate | Electronics | 8 | 02-19-2008 08:52 PM |
momba max vs. novak goat vs. novak rooster crawler | punkafi888 | Electronics | 4 | 01-20-2008 02:05 AM |
Novak Rooster Crawler Edition ESC -- The Crawler Store | EeePee | Vendors Market | 20 | 07-30-2007 09:19 PM |
