07-07-2013, 12:02 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
| sidewinder sct problem
i have a sidewinder sct that i have ran in my twin hammers for a while now. it is coupled to a tekin ROC 412 motor, running sensorless. i turned it on, nothing different, start-up jingle, but only 2 beeps happened instead of 3, and no finishing jingle. steering and shift servo work, but no throttle. the wires are all in good condition and connected to the motor well. the ground wire is frayed some, but is still attached. so, i dont know if i need a new esc, or what. thanks for your input. |
07-07-2013, 07:19 PM | #2 |
| Re: sidewinder sct problem
First thing to try: Center your throttle trim Check your throttle / brake EPA's (travel) are set at 100% Calibrate the ESC to your transmitter If you have a Futaba radio you need to use your servo reversing switch to reverse. If that doesn't help, here are the LED codes for troubleshooting. If you are not calibrating and have no throttle input then: Flashing Red and Yellow = over temp Flashing Green and Yellow = low voltage cut-off(battery) Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0. Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse Flashing Yellow = possible problem with controller Solid Yellow = indicates neutral and armed Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver. If you are applying throttle or reverse when NOT calibrating: Flashing Red and Yellow = over temp Flashing Green and Yellow = low voltage cut-off(battery) Flashing Green OR Red = indicates partial throttle (green) or reverse (red) Solid Green OR Red = indicates full throttle (green) or reverse (red) Flashing Yellow = possible problem with control Solid Yellow = should never happen Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver. If you are applying throttle or reverse WHEN calibrating: Flashing Red and Yellow = should not happen when calibrating Flashing Green and Yellow = should not happen when calibrating Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse. Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled. Solid Yellow = indicates neutral has calibrated and is armed Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver. |
sidewinder sct problem - Similar Threads | ||||
cc sidewinder sct in scx-10? | 4x4 lover | Electronics | 9 | 01-19-2012 07:16 PM |
CC Sidewinder SV2 vs SCT | brazwewn | Electronics | 6 | 07-23-2011 06:04 AM |
sidewinder sct | asw27x | Electronics | 11 | 04-24-2011 02:29 PM |
Sidewinder SCT | BluFalcon | Electronics | 0 | 04-13-2011 07:43 AM |
sidewinder and sidewinder SCT troubleshooting | nstn8 | Electronics | 7 | 01-17-2011 07:50 PM |
