07-08-2013, 05:01 PM | #1 |
| LiPo 2s to 3s switching ?
just curious... Was wondering if it were possible to run two batteries on board that could be switched mechanically or electronically... and would allow a user to choose (switch) between either a 2s or 3s LiPo ? In theory... the effect would be like have a nitrous switch. shutting down the 2s connection from the system and alternating to the 3s. Was thinking of on the fly switching ( ^ tho' stopping momentarily during switching would be acceptable) Not the same thing as physically plugging in each battery individually when extra power is wanted. But a different approach with similar results. Is something like this even possible ? Or would TX/RX recalibration make this idea a fail ? |
07-08-2013, 05:05 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: LiPo 2s to 3s switching ?
you would still have stopping time from esc arming which is usually 1.5s
07-08-2013, 05:12 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Why don't you just run it on 3s?
07-08-2013, 06:29 PM | #4 |
| Re: LiPo 2s to 3s switching ? 'cause I don't need the extra power all of the time... and would think the 2s would offer less wear to the motor's comm/brushes then when using 3s full time. Maybe it wouldn't be worth the hassle of it... wuz just curious if it had ever been done before !? |
07-08-2013, 06:47 PM | #5 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Never heard of it being done, but its possible. There isn't any extra wear to your gear if you run 3s. In any case, it would be easier to just use less throttle when you don't need the power. If your radio has an exponential function, that would help too.
07-09-2013, 11:30 AM | #6 |
I think your looking at more trouble than its really worth. I think cycling your electronics between packs will be a lot rougher on your equipment than 3S will be on your motors. If you don't want that much power all of the time, don't squeeze the throttle as much. |
07-09-2013, 12:04 PM | #7 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
You could run the rx and servos off the 2s battery all the time. then a relay to switch the esc power to either battery. With the relay switched from a rx channel. Possible, yes. Lot of trouble when you could just squeeze half throttle instead.
07-09-2013, 06:15 PM | #8 | |
| Re: LiPo 2s to 3s switching ? Quote:
B: You're really concerned about brush wear? Then go BL C: Putting a 3s lipo to a brushed motor is at about the same voltage as a 7 cell nimh pack which takes a while to wear down brushes so you really shouldn't worry about it. Last edited by Johnnysplits; 07-09-2013 at 06:19 PM. | |
07-09-2013, 07:34 PM | #9 | ||
I know how to change brushes... just don't want to do that often. I'm not buying into the necessary components for a brush-less system. Quote:
a 3s LiPo sports 11.1 v (12.4 v full charge) So a nimh would need be 8 cells to compare (9.6 - 12.8 v) ? thought nimh were 1.2 v per cell... but could be peaked to 1.6 v ? :duinno: I'm no battery guru... so please correct me if I've got it all worng Last edited by TacoCrawler; 07-09-2013 at 08:02 PM. | ||
07-09-2013, 07:35 PM | #10 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Having the Drag Brake cranked will create extra wear on the motor brushes. And 3S is FUN all the time.
07-09-2013, 08:06 PM | #11 |
| Re: LiPo 2s to 3s switching ? |
07-09-2013, 08:15 PM | #12 |
The drag brake is controlled via the ESC, but there are variables, such as the design of the motor and how the rig is geared. You would have to adjust the amount of drag brake the esc applies by following the esc's programming steps. Usually, it is done with a CastleLink if it's a Castle based product, Tekin has their HotWire, other manufacturers have field programming cards. I don't believe the pack voltage has an effect on the drag brake, not 100% on that though. |
07-09-2013, 10:20 PM | #13 |
yeah I gotta buy into that CC link still just hooked up my 3s thru my AE-2... no bueno thought I read that others had gone to a 3s on the AE-2 without issue !? not the case for me... seems to starve the servo... or just glitches very noticeably guess I'll need to install my CCbec to run the 3s LiPo's !? ~I have no excuse for delay, just laziness~ a different topic... Axial/Hobbico sent me a Fut S3305 servo as a warranty replacement for my failed AS-3 servo... Seems the Fut. S3305 is a little underpowered, compared to many... But seems to net decent reviews... Think it's a better servo then the AS-3 ? yes-no ? ^ was free to me... (warranty replacement) so I guess I shouldn't complain unless you all might think I should !? Lol |
07-10-2013, 09:24 AM | #14 |
Newbie Join Date: Jul 2012 Location: hamilton
If you don't need 3s power all the time just run 3s' s and learn throttle control.. that way you can run then when you need the power smash it down and go....
07-10-2013, 04:43 PM | #15 |
| Re: LiPo 2s to 3s switching ? Back in the day when I raced 2wd mod buggy, yes I would peak the pack out to almost 11v then throw it in the car and race. But I was running matched sanyo cells which made a big difference. Don't sweat using a 3s lipo.
07-11-2013, 03:32 AM | #16 | |
| Re: LiPo 2s to 3s switching ? You might not need to use it all the time, but you need to have it available for use. (*) Quote:
The drag brake operates by providing a voltage to pull the motor in the opposite direction of what it's running. At times where the 2S voltage is insufficient to hold the motor still a 3S battery should make a difference. Not that this is likely to ever happen though... _______________ (*) It's a bit like the motor solution for the Swedish MBT called strv 103, or "S tank" as it's more known abroad. Diesel or turbine engine? Diesel has the advantage of very low fuel consumption on idle, but it's bulky and heavy. Turbine is smaller and light weight but a real fuel hog on idle. A tank (just like a crawler) spends most of its time on or near idle, with a few instances of need for high power in between, so the tank designers reasoned: "Let's have both types of motor. A diesel to run all the time, and a turbine to add power when needed." Problem was that the turbine takes a comparatively long time to start, and extra power is always needed at very short notice. ("We're being shelled and need to get away NOW!") Therefore in practice the turbine had to be on (and idle) most of the time anyway... | |
LiPo 2s to 3s switching ? - Similar Threads | ||||
Switching to lipo? | RallyeX | Axial Wraith | 5 | 04-08-2013 10:07 PM |
Switching to LiPo | scoggdog13 | Electronics | 2 | 03-24-2013 05:30 PM |
Switching from Lipo to Nimh, what needs to be done? | needtocrawl | Axial Wraith | 9 | 04-22-2012 01:40 PM |
im switching to lipo | mini freak | Electronics | 4 | 12-15-2011 06:43 AM |
