10-02-2006, 08:30 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Port Angeles
| Which batteries?
Im looking at a few different battery packs but i cant seem to choose one. At rcmart.com you can get a 6 cell Intellect 3800 pack for $29.90 and all kinds of other crazy deals but i dont know what will be the best balance of power and run time. Can anyone help me decide which batteries to get??? BTW im planning on running 2 integy 65 or 75t lathes |
10-02-2006, 08:39 PM | #2 |
Quarry Creeper Join Date: Jan 2005 Location: Orem, UT
Ditch the sub-C packs and go lipo.
10-02-2006, 08:57 PM | #3 |
i wanna keep the sub c cells cuz i already have a charger for them, so besides lipos what should i use, and another question is, will steering servos and motors short out or anything if they get wet?
10-02-2006, 09:01 PM | #4 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
subc are good choice plenty of runtime and if properly placed, added traction. As for waterproofing: wrap your ESC and receiver in ballons to protect them from water, and use a watterproof servo. the motor if it a lathe should have a problem with water, just remeber to clean it out and lube the bearings/bushings after.
10-02-2006, 09:13 PM | #5 |
the lathes SHOULD or SHOULD NOT have a problem with water?
10-02-2006, 10:12 PM | #6 |
should not sorry bout that.:-P
10-02-2006, 10:27 PM | #7 | ||
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
It's a DC motor. As long as you do some maintenance afterwards it'll be fine. Several folks break in sealed endbell stockers by running them underwater. Servos are fairly resistant to water intrusion. | ||
10-02-2006, 10:52 PM | #8 |
k thanks guys, winer is coming up and i didnt wanna ruin my gear, im looking forward to snow wheelin!
10-02-2006, 11:05 PM | #9 |
Rock Stacker Join Date: Sep 2006 Location: Victoria BC Canada
Not to hyjack another mans thread, I feel my question is right in line. Are most guys buying prebuilt packs of sub c or are they building their own? Is six cells per pack standard? Are deans connectors used? As fr as recharging, is six amps the standard? Is discharging and cycling required? Do you repeak before each run? RYY |
10-03-2006, 10:26 AM | #10 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
NiMH do not require cycling.... never hurts but NOT required, I use deans whenever there is going to be high draw. I like to repeak mine but if your not racing is not necessary. I charge about 5 amp or so
10-03-2006, 04:38 PM | #11 |
when i quick charge i use 4 amps but for normal charging when not in a hurry i only charge at 1amp. on a 4200 it takes a while but it gives a much better charge and is easier on the batteries
10-04-2006, 09:50 PM | #12 | |
Quarry Creeper Join Date: Aug 2006 Location: So*Cal
| battery types... Quote:
http://cgi.ebay.com/20-Pcs-of-Matche...QQcmdZViewItem and then just have 4 packs custom built at my local battery shop... (BTW are these any good batteries? if they are, then I'm going to buy them.) thanks for info! | |
10-05-2006, 01:21 PM | #13 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
you can find 4 - 6cell 3500 subc packs on ebay for 60 bucks shipped all the time.... I have been running those packs in my basher and my crawler for 4 months now...
10-05-2006, 08:55 PM | #14 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Form my experience on my clod, a 7 cell offset brick 4/5A pack works the best besides lipo. I have access to any kind of RC battery known to man, so I get lots of time to experiment. I just ziptie the pack I described to my front diff on the top of the axle and it works great. Heres a pic: |
10-05-2006, 09:33 PM | #15 | |
We don't have a high amp draw in a crawler, so even an old 1500 will work...pretty much any battery (not all ) that has some sort of capacity will power a crawler. I tend to stick to Sub-C cells. I outlined why here: What size cells? | |
10-06-2006, 07:01 PM | #16 |
cool that was pretty helpful. looks like i'll be putting a few sub c packs on my 2.2 tlt
