07-12-2013, 06:23 PM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Amsterdam
| Crawler Motor Advice - outrunner useful or not ?
Hi, I've just bought an Axial AX10 Scorpion with a bunch of spare parts and a motor installed - but no Esc, servo or battery. The installed motor is a brushed LRP Truck Puller 2. For the time being, I've ordered a cheap-as-can-be Hobbyking X-car 45Amp ESC just so I can have something to play with. I happen to have a Protek 150T servo incoming which will be useful in this build as well. I currently have 2s2p 7000mAh batteries around from my ShortCourse truck, but I might as well buy something else. I know the kit I'm buying includes the **ax30490 - Axial AX10 Scorpion Outrunner Motor Plate.** So, in short, I have an AX10 with *currently* a (Brushed) LRP Truck Puller 2, Protek 150T servo, HK Brushed X-car 45A esc, and 2S batteries tah are really heavy... If I'm thinking about buying a new motor, esc and battery (and maybe bec), what would be the most awesome way to go ? When given the freedom to choose, would it be most awesome to go for a (brushless) outrunner motor ? (Or if not, what else ?) And when the motor is determined, what most awesome Esc / Bec / Battery would suffice ? |
07-13-2013, 06:56 AM | #2 |
| Re: Crawler Motor Advice - outrunner useful or not ?
First question is, what do you want the rig to do? Crawl Scaler Mud/water runs Basher That determines recommendations. Yes, 7000mah packs are large, a couple of 3500's would be better in most cases. Whatever you get, make sure you have decent battery connectors (not Tamiya) for everything. |
07-13-2013, 07:52 AM | #3 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
imo.. Mamba Max pro esc Tekin 13.5t sensored brushless motor perfect blend of speed and crawlability gear it for crawling/speed with spur/pinion tranny gears slow stay with 48p gears..80-91t a bit faster speed gear with 32p gears..52-60t |
Crawler Motor Advice - outrunner useful or not ? - Similar Threads | ||||
first crawler, need motor advice | Hammertone | Team Losi Comp Crawler | 0 | 01-28-2013 06:59 PM |
outrunner motor | cytogen | G-Made Crawlers | 4 | 01-11-2013 04:53 PM |
outrunner motor - which one? | wminmi | Axial AX-10 Scorpion | 2 | 03-01-2010 08:10 PM |
540 size outrunner on AX10? pls advice | kaho0338 | Axial AX-10 Scorpion | 6 | 06-03-2008 02:06 PM |
