07-14-2013, 05:03 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: tallahassee
| new brxl no throttle
Red light just flashes on the brxl with no throttle. Iv checked to make sure theres no power to the motor. I'v tried to cail the brxl but nothing. Heres a pic of my set up if its wrong please let me know, but it ran like this through a few batterys |
07-14-2013, 05:12 PM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: new brxl no throttle
I had that problem. You have to go thru the first steps again. Turn on the radio. Make sure your BR-XL is plugged into channel 2. Plug in the battery and before the BR-Xl arms hold full throttle, when it beeps go to full reverse. It will beep again. Your done.
07-14-2013, 05:25 PM | #3 |
I've tried that about 10times it never beeps or changes just flashes red.
07-14-2013, 05:48 PM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
check Ur tx batts sounds like it isn't binding oh and make sure there is no trim on controller for the throttle
07-14-2013, 07:20 PM | #5 |
Brand new batterys in tx
07-14-2013, 07:41 PM | #6 |
| Re: new BRXL no throttle
Does your steering still work?? If so, the radio binding is likely OK. You could always plug the servo in the throttle channel to see if that channel still works. Reading this.... Castle Creations | FAQ: 1/10th Scale Products Recalibrate as mentioned. Set TX throttle trims to "0" Throttle EPA's to 100% No expo Then calibrate. May need to reverse the ESC direction. |
new brxl no throttle - Similar Threads | ||||
BRXL Giveaway & The Next Team Driver Contest - 1 RCC User will win a BRXL this week!! | Locked Up | General Crawlers | 205 | 10-22-2012 10:49 AM |
No throttle? | lowslowTJ | Electronics | 3 | 12-02-2009 03:39 PM |
